My car is a bitch:( but damn I love it
Old Jun 19, 2002 | 10:39 PM
Tim Benton's Avatar
FD title holder since 94
Decided to give the old turbo swap a try. I got some 99 spec turbos from Jesse Lau and haven't taken the time to take it to the shop to have them do it, so I decided to give it a try. In the past, any mods I've done on the car has ALWAYS has some freakin' problem, usually it being oone bolt that won't break loose or rounds itself off. So I knew going in that I'd have trouble.
Take all the stuff off to get to the DP and turbo assembly. In 3 hours time, I'm down to 2 studs on the turbo housing and the unit will off. Crap my pants, both bolts WILL not come off, soaking it for 30 minutes (now soaking over night) won't budge, 1 busted/swollen knuckle, 2 banged and bruised forearms and wrists and still no luck, then I get low on arm strength from the beating my car is giving me and can't make them move. Any suggestions on removing the 14mm bolts? Prayer anyone?
Tim
Old Jun 19, 2002 | 10:43 PM
dlee's Avatar
Try heating it with a torch and then take them off. Good luck.
Old Jun 19, 2002 | 10:45 PM
Want2race's Avatar
Bigger and better things
i had the exact same problem!
there is only one answer...
Take a hammer and chisel and brake the seat loose.. It takes some hitting... then try with the rachet... worked for me... But only after i tried to drill thru the damn thing..
its out of focus but that what it looked like.. I drilled thru half.. then decided to try a rachet and it worked easily!
Old Jun 19, 2002 | 10:49 PM
Tim Benton's Avatar
Jonathon,
these turbo swaps are a pain in the ***. One of the bolts is the one in the middle, sort of hidden. other one is the top right, from underneath looking up at the assembly, near the actuators. Either way, tho
se sum bitches are coming out tomorrow
Thanks for the idea too
Tim
Old Jun 19, 2002 | 11:12 PM
Want2race's Avatar
Originally posted by Tim Benton
Jonathon,
Tim
thats the same one that i had **** from...
Kick its *** man! just remember... you cant break the damn thing.. and since the base is heat seized on you need to physically break it loose.. And a racket and socket is the least effective way of doing that! Long thing chisel worked for me!
Old Jun 19, 2002 | 11:14 PM
Want2race's Avatar
You are here
Did it once.. NEVER again!
Good luck.. not even money would make me try it again!
Old Jun 19, 2002 | 11:16 PM
Rogue's Avatar
Originally posted by Want2race
Is there a reason you have the Want2race.net tag on all the pictures you're posting? do you really need the hits that bad? or are you worried about "copyright infringement"?
Old Jun 19, 2002 | 11:17 PM
slopoke's Avatar
yea i recently did mine too, and the way i got mine off, (i had one stuck one) was a half inch drive 24inch rachet, jsut a little tug on that and it came rigfht out, i couldnt get it to move with anything else, so i finally got pissed, and said, well if it breaks then damnit the turbos will be off and i can drill it out easier, good luck, scott
Old Jun 19, 2002 | 11:22 PM
Want2race's Avatar
it was on a webpage made by a program called arles.. aparently it edits the pic.. i had the domain. but dont really care anymore.. so its there... too much effort to remove it...
Old Jun 20, 2002 | 03:02 AM
Silex's Avatar
Cool, my name is Scott too. We rock.
plentymoon
NW RX-7 Forum
Sep 5, 2015 08:55 AM
WLD.RX7
Aug 16, 2015 09:43 AM
