Quick T/O bearing question
Old Apr 9, 2010 | 03:17 PM
food7373's Avatar
Kid
Today I was "testing" the throwout/release bearing. I have the tranny on blocks in my garage and I put on the T/O bearing and pushed it from where the rod pushes it on the slave cylinder. When I push it too far, it gets stuck when it comes back in on a small lip inside the bearing. It's a Koyo model, and I was wondering when you push the clutch in, how far does the throwout bearing go out, because it doesn't catch on the lip until it reaches the point where the lip is, which is about 1/2 inch or a little more. Thanks for the help guys.
Old Apr 9, 2010 | 04:41 PM
rxtasy3's Avatar
the bearing doesn't move no where near as much as what ur moving it. maybe 2-2.5" of travel.
Old Apr 9, 2010 | 09:33 PM
food7373's Avatar
Kid
Then the bearing would almost go off where it rides on, or it seems like. I will take pictures tomorrow of the section in the middle that has the lip and gets caught. I just don't want to put the tranny back in to find that the bearing gets stuck.
Old Apr 9, 2010 | 10:14 PM
kencunm's Avatar
Veteran: Navy
You'll be fine. I'm in the middle of a clutch job and am doing the exact same thing you are. In fact I'm waiting for a part so you might get done before me. What you've described is normal.
Old Apr 9, 2010 | 10:56 PM
food7373's Avatar
Kid
Okay, thanks for the reassurance. I just didn't want to have to take out the tranny again. You most likely will get done before me because I'm still waiting for my pilot bearing from Mazdatrix (takes them a long time to get it out to east coast), and I still haven't gotten the old one out. Haha.
Old Apr 11, 2010 | 05:07 PM
food7373's Avatar
Kid
Here's some pics of the bearing.
Inside the bearing.
The bearing.
Attached Thumbnails Quick T/O bearing question-img_1087.jpg   Quick T/O bearing question-img_1084.jpg
Old Apr 11, 2010 | 10:59 PM
rxtasy3's Avatar
please change the setting on ur camera. the original images r too large when making them show up in the post.
Old Apr 12, 2010 | 04:52 AM
mazdaverx713b's Avatar
Have RX-7, will restore
thats not problem at all. the t/o bearing doe not move that far on the input shaft's collar when the trans is back in. just make sure you put a little grease on the input shaft's collar where the bearing rides and a little on the bearing's housing where it rides the collar.
Old Apr 12, 2010 | 05:47 AM
food7373's Avatar
Kid
Okay, sorry about the large pictures. I will change the setting. But thanks a lot for the info. I was getting a little scared it would be getting caught.
