Starter wiring please help!!
Old Jun 19, 2002 | 08:47 PM
DC350's Avatar
Rotor Head
Yo guys
I'm hooking up the starter right now and there are 2 contacts which you can bolt on to the starter, I know which one I have to put on the starter but I am unsure what to do with the other...Thanks so much guys...
Evan
Old Jun 19, 2002 | 11:53 PM
DC350's Avatar
Rotor Head
Bump
Please help!!!
Old Jun 19, 2002 | 11:58 PM
SonicRaT's Avatar
Super Raterhater
Explain this a little better, you mean on the solonoid? Or do you mean, you have two big-*** black wires and you're not sure which is which? The one with the yellow-stripe and a circle ring is the ground, it should be bolted onto the transmission with the tranny bolt just above the starter. The one that looks like it's recantuglar is for the starter, is that what you mean?
Old Jun 20, 2002 | 01:11 AM
DC350's Avatar
Rotor Head
Man, You are DAMN smart! So, that wire with the yellow strip bolts onto the tranny. OKay, Thats that subject cleared. BTW thanks, and on the other side of the tranny, there is another black wire (skinny) i think it's a ground as well, connect to the tranny? Thanks so much man!
Old Jun 20, 2002 | 02:09 AM
DC350's Avatar
Rotor Head
pleasE? anyone out there? hehe
Old Jun 20, 2002 | 02:12 AM
SonicRaT's Avatar
Super Raterhater
Yes, you are correct. Sorry for the delay, there is like a little 10 or 12 mm bolt right on the top of the trann (it's not facing the engine, it's pointing up and down) It gets connected there. Mine broke off so I just ran another ground to the tranny bolt
Old Jun 20, 2002 | 02:17 AM
DC350's Avatar
Rotor Head
okay, awesome. Thanks so much. Now the whole thing should be done tomorrow. I hope to video tape some of it It's a good idea to put more grounds to the engine...just reinforce right? Thanks
Ev
Old Jun 20, 2002 | 02:23 AM
SonicRaT's Avatar
Super Raterhater
yes, it is. I had to do this on my GXL. I ran a big wire from the front cover to my negative terminal, and a couple on the other side of the engine to the chassis, and one that comes around to the negative terminal as well.
toplessFC3Sman
Mar 20, 2018 01:54 PM
Monsterbox
Sep 11, 2015 03:29 PM
