Siezed Axle
Old Apr 5, 2010 | 12:51 PM
Verneuil's Avatar
MD Siezed Axle
So i tryd installing my LSD. But ran into a problem, And as the title states its a siezed axle. The passanger side came right out but i pouned on the drivers with a slide puller for a while with no luck. Put a ton of PB blaster and a little heat with no effect. Any tips would be greatly appreciated. BTW its a 83 and if i rember correctly from what i read in other posts its a big bearing rear. Its got the through bolts on the drive shaft to diff. Thanks
Old Apr 5, 2010 | 05:47 PM
IanS's Avatar
Ricer
83 is a small bearing axle. Always.
Old Apr 5, 2010 | 09:40 PM
Verneuil's Avatar
really. Hmmmm, My bad. Still dam thing will not come out. I really would like to get my lsd in.
Old Apr 6, 2010 | 01:08 AM
Siraniko's Avatar
RX for fun
The axle is secured by a plate with nuts and bolts. I hope you didnt forget to unbolt them.
Old Apr 6, 2010 | 05:18 AM
Verneuil's Avatar
There secured by what? Hahaha. Ya i didnt.
Old Apr 6, 2010 | 11:25 PM
Stevan's Avatar
You need a larger slide hammer.
Old Apr 6, 2010 | 11:41 PM
Siraniko's Avatar
RX for fun
no need to spend $$$ on buying or renting a slide hammer. My wacky special axle puller consists of long factory SA lug nuts and a stock rim only. Some people use this combo along with a BFH
Just install your rim inside out backwards (spare tire for those with aftermarket rims) with lug nuts installed half-way in. this will give you enough play. with just a few thugs, the axle should slide out.
Old Apr 7, 2010 | 12:00 AM
Stevan's Avatar
I used a 6 ft barbell, with a lug bolt in secured in one end, and just a bolt through the bar at the other end for a stop. Use as many weights as needed, clamped together as one weight.
Old Apr 7, 2010 | 12:03 AM
Siraniko's Avatar
RX for fun
thats a complete work out homie.
Old Apr 7, 2010 | 12:08 AM
Stevan's Avatar
Yeah, a little fab time, works well though.
Old Apr 8, 2010 | 06:17 AM
Verneuil's Avatar
I dont have a barbell Ive used the stock wheel trick but there was not enough to move it.
Old Apr 8, 2010 | 03:11 PM
Stevan's Avatar
Bolt a chain to the axle, and something heavy to the other end of the chain.
And be careful.
Andrew7dg
Aug 6, 2017 01:41 PM
James Knox
Oct 5, 2015 07:56 AM
