identify this turbo!
on
was an upgrade on the turboII motor I got. any help is appreciated, if you know what it is do you also know what the common power levels are for it as well?
the marking are as follows:
there is a "T" on the polished portion of it so I assume a Turbonetics turbo?
65N
PD289
I-668
and here is a pic of it:
65N
PD289
I-668
Top Down, Boost Up
Got a better picture? If it has a stock hotside, it's some sort of hybrid. Some hybrids for comparison can be found here: http://bnrsupercars.com/
on
somewhere I do... I will find one. it has a "huge" exhaust housing. also has a 3.5" greddy DP, looks visually like 4" but didn't know if they made those... its BIG.
looks almost a large on the exhaust side.
put my GT2871R up next to it, and it mare the Garret look pretty small..
on
side shot. looks to be water cooled as well? has a circular logo, and the "T" I mentioned earlier... I suppose the size of the injectors on the car would give me a decent idea on that size range it is...
Top Down, Boost Up
Yep, it's a hybrid as I was guessing. If you remove the compressor housing and measure the diameter of the inducer & exducer (on the wheel), I can give you an idea of what it is and what power levels it's capable of.
Check here if you need info on the inducer/exducer: http://www.moddedmustangs.com/forums...ze-r-trim.html
Trending Topics
on
oh ok, I will have to take more detailed pictures too then, also on the backside of the "coldside" it looks like the houseing is CNC? pretty slick peice really. I will have to do a trial fit this week in the car to see what will have to be butchered to make it all fit.... got to love a good session with an angle grinder....
