Resoldered cpu... now why ....?
Old Jun 18, 2002 | 10:50 PM
seventhgear's Avatar
boost on the way(GTU II)
Question Resoldered cpu... now why ....?
resoldered the cpu and its still ****** up . my home fuse will still keep all the electronics on when the key is out and door closed im pissed! please help maybe it could be something else ( hopefully )
thanks
jack
Old Jun 18, 2002 | 10:58 PM
Sniper_X's Avatar
I dont understand... Home Fuse?
Please outline the problem in a bit detail.
I can help you if I can get a clear indication of whats happening.
Make me feel like im there experienceing it please.
Old Jun 18, 2002 | 11:06 PM
DAMNIT IM SORRY I SAID THAT again i mean room fuse imma dumbass lol
ok so i put the room fuse on and all the light on the dash come on all the warning lights and the chime bell rings ok ?
well if i close the door with the key being out of the ignition all the lights stay on and will continue staying on if i do not remove the room fuse ... better now? hope so cuz i dont think i culd xplain n e better than that lol well here ya go thanks in advance
jack
Old Jun 18, 2002 | 11:10 PM
Sniper_X's Avatar
well, FIRST, remove the door pins.
then isolate them from the body and see if the door light still stay on.
Did this start AFTER you resolderd?
If so, you have a solder bridge somewhere.
recheck your work, you slopped solder somewhere it shouldnt be.
Let Me know
Old Jun 18, 2002 | 11:17 PM
NO IT WAS HAPPENING b 4 and figured this would cure it guess not
Old Jun 18, 2002 | 11:28 PM
Sniper_X's Avatar
Then follow the other idea.
The problem is clearly that the wire has shrted to the body at the door pin switch.
One philips head screwdriver, 5 minutes, and you can tell me if im right
Old Jun 18, 2002 | 11:30 PM
COOL OK ILL BRB
Old Jun 18, 2002 | 11:35 PM
HEY WELL I KANT TRY IT YET BUT WHAT DO I DO AGAIN?? unscrew the screws and then what ?
Old Jun 18, 2002 | 11:37 PM
SORRY IM WRITING SO MUCH BUT just see if the door lights stay on while i put the room fuse back in ? and if it does what do i do then ? tape the wires? sorry
jack
Old Jun 18, 2002 | 11:38 PM
Sniper_X's Avatar
Why cant you try it?!!!!!
There is ONE wire attached to the door pin switch.
This wire, when grounded, turns an the room circuit.
If its loose/ broken /stuck then it is going to ground itself eventually.
Leaveing the room circuit on all the time.
Im "PherensicOgaloid" on AOL IM. (now)
Old Jun 19, 2002 | 07:44 AM
CAN SOMEONE else help me i have tried the door pin thing and no luck .... what else could it be???
or maybe im not doing the door pin thing right !!!
jack
Old Jun 19, 2002 | 07:50 AM
RETed's Avatar
First of all, the CPU has NOTHING to do with the door switches/dome light/console lights.&nbsp The CPU does control the horn/turn signals/hazards.
It sounds like electrical wiring is screwed.&nbsp Does the car have some kinda alarm or car stereo system installed?&nbsp I bet someone screwed with the wiring.&nbsp Electrical troubleshooting is very hard and time-consuming.&nbsp Don't expect us to type out a 2 minute reply and expect that to fix your problem.&nbsp It requires a FSM and lots of time (I'd say almost the whole day) to track down all the circuits just to find the culprit.&nbsp Then you still gotta fixc the problem!&nbsp If you're lucky, it's just a shorted wire; if you're unlucky, you're looking at a several hundred dollar replacement of a Mazda OEM part that the Mazda dealers only sell.
Stop being demanding - this is easily a couple hundred dollar repair job from a competent shop.
-Ted
Old Jun 19, 2002 | 08:10 AM
wtf? im jus asking questionz so u stop being rude! **** bro im sorry how else am i supposed to ask ???
stop jumping to conclusions and if i bother u so much bein "demanding" then dont answer my questions !!!!
Old Jun 19, 2002 | 08:16 AM
RETed's Avatar
Yeah, why don't you go **** yourself at the same time.
This board is a voluntary one.&nbsp We're under no obligation to answer your questions, nor do we have to listen to your childish rants.&nbsp You can't go demanding **** cause this place is free - you willing to pay for it?&nbsp Obviously you're not - we're trying to save you some money, and all you can do is bitch...
-Ted
Old Jun 19, 2002 | 08:26 AM
dont **** wit me bitch talkin about my childish rants ! I DID no such thing u ***! i was making it crystal clear to u that i was not demanding any answers of u ok and now that u dont see it i can declare u incomptent! u say its voluntary to answer my questions well hey simple ......dont answer mine then .... i felt as if i was not demanding as u said i even went back and read my post and no i still feel as if i was asking properly u must have something up ur *** wanting to **** with younger people
peace out !
Old Jun 19, 2002 | 08:44 AM
RETed's Avatar
Swearing and vulgarities have no place in here.&nbsp Need I have to define what those are?&nbsp How old are you?&nbsp Still in high school?
See above - your comprehension sucks.&nbsp Still in grade school?
Maybe your memory is going bad too...&nbsp Just for your reference:
I think you need to explicitly state you don't want me to say anything.&nbsp I haven't heard any explicit instruction until now.
Why don't you put in the time to properly put together a coherent sentence and use punctuations.&nbsp What's your excuse?&nbsp Still in kindergarten?&nbsp I'm not "******* with younger people" - I've got a problem when you type you're on drugs.
hey maybe i should type like u ...now can u understand what i'm trying to tell u? maybe ur keyboard is broke ... hey these periods are cool .....does it make more sense now that i type like u?
Or do you need the... ShiFT Mad QuiCk y0?
peace out !
Somehow I doubt that...
-Ted
Old Jun 19, 2002 | 08:46 AM
The Ace's Avatar
Greek Power
Gee, I wonder how long it'll take for this thread to be locked....
And Ted, obviously seventhgear is younger than you and me, and does not have a sound knowledge of electrics/electronics, so cut him some slack....
Old Jun 19, 2002 | 08:49 AM
RETed's Avatar
Originally posted by The Ace
Any Ted, obviously seventhgear is younger than you and me, and does not have a sound knowledge of electrics/electronics, so cut him some slack....
If this is the case, then the bitch better be taking the car to a shop that can competently fix his problem.&nbsp We're wasting our time trying to explain how everything works, and how to fix this problem.
-Ted
Old Jun 19, 2002 | 11:16 AM
rxse7en's Avatar
Nothing to see here.
I find it amazing that RETed is ALWAYS trying to help EVERYONE and he always seems to get the brunt of some newbie's frustration! What is it with you people? Would you talk to a stranger trying to help you in person the same way? BTW, it's not Ted's job to be "understanding," it's the kid's responsibilty to be civil and not get so frustrated when he doesn't understand an explanation!
Thank you Ted for all of your help. It's people like you that make owning/maintaining these cars easier and more pleasurable.
B
Old Jun 19, 2002 | 11:32 AM
RexMan's Avatar
For a person like me, who knows next to nill on a rotary, I find this forum full of good write ups, excellent folks with lots of knowledge and even some good friends.
For anyone to come in here and act up, as I've seen in some of the posts, is just very immature.
If my 20yr old son acted like that in front of others, I have to say he would get his *** thrashed....by me....and yes, I do have a 20yr old son.
Old Jun 19, 2002 | 11:45 AM
HAILERS's Avatar
HAILERS
Just curious. When you start the car, engine running, what happens to the idiot light cluster on the dash?? Do the lights go out with the engine running. I do understand they all stay lit up with the key out. I'm just talking about the cluster of idiot lights where the clock is. Nothing else. Thank you.
EDIT: What year car do you have??????? Turbo or non turbo?
Old Jun 19, 2002 | 11:14 PM
NON TURBO 87 the idiot light cluster on the dash clears up and goes away when the engine is running.
Old Jun 19, 2002 | 11:21 PM
well guys im actually 18 and currently out of high school and enrolled into unc charlotte and im really not a "dumb little kid". i swear i wasnt demanding of any thing. i always have my caps locked when im instant messaging for the font i use and if my "slang" typing bothers u so much that its the only thing u can make fun of then i do not know what to tell you but bro im sorry for what u think was demanding
do not go postal everytime u see a "dumbass kid" bitching obviously you are too old for that hmm??
but i did say it was rude of you to say that i was demanding . at least say it in a nicer way but all in all my bad!
SLANG~~~ peace out ! ~~~~SLANG
JACK
Old Jun 19, 2002 | 11:35 PM
I wonder if he ever figured it out ?
Old Jun 19, 2002 | 11:36 PM
SonicRaT's Avatar
Super Raterhater
Sound's like your ignition switch isn't working properly. you could probably take the plastic covering off of it and check the switch with a multimeter, I believe the FSM might have something about this (http://www.fc3s.org under how-to)
