90 auto 'vert
Old Mar 23, 2010 | 09:02 AM
skullzaflare's Avatar
WV 90 auto 'vert
i picked up a 90 automatic vert in VA saturday for $350, sat for 2 years at a shop
it has a oil leak, im assuming oil lines or sending unit
first problem, on an automatic, when it shifts into 2nd, is it suppose to delay? and when it shifts, is it suppose to feel like someone riding the clutch shifting til its in?
next, i just drained all the old gas and put fresh in it, its running better, but it still has a "miss" sound to it, and it will idle at 1200-1900
any help?
Old Mar 23, 2010 | 03:33 PM
also, while driving it around the block yesterday, i had a check engine light, i just checked it, i got this
27 - MOP (General) - Basic Fuel Injection and fixed timing
Old Mar 23, 2010 | 05:40 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Your metering oil pump has failed, and will need to be replaced. The engine will have no power until you take care of it. Basic fuel injection and fixed timing is limp mode.
Old Mar 23, 2010 | 05:45 PM
it did that yesterday, but since then is fine, other than problems in first post
so could that be all my problems except the trans?
i plan to do a 5 speed swap when i get the parts, but for not i just wanna get it roadworthy
Old Mar 23, 2010 | 05:51 PM
Top Down, Boost Up
If it's intermittent, I'd check the wiring to the MOP. It should not go in and out of limp mode. Testing the MOP per the factory service manual (FSM) would still be a good idea. You can find links in the 2nd gen FAQ.
I can't help you with the auto transmission issues, but the FSM will point you in the right direction. I've never had anything other than a manual.
Old Mar 23, 2010 | 07:19 PM
ok, though i think ill devote my attention to finding the oil leak now, i looked down, its 1 drip a second.
the hose connections arnt leaking, nor the sending unit, i see a stream running back the oil pan lip from under the a/c compressor, any idea what it is?
Old Mar 23, 2010 | 07:55 PM
red87tll's Avatar
needs a cheaper hobby
hey bud where are you from?
Old Mar 23, 2010 | 08:00 PM
bunker hill, close to summit point raceway
Old Mar 24, 2010 | 02:00 PM
i think i need new struts too
http://i15.photobucket.com/albums/a3...e/CIMG1896.jpg
anyway, found a omp, buying it soon.
as far as oil leak, we are thinking its the oil pan, any other thoughts?
Jetlag
Sep 29, 2015 06:52 AM
MidnightOwl
Sep 25, 2015 10:24 PM
