help with 86 n/a rx7 losing power
Old Mar 19, 2010 | 12:15 PM
mc86rx-7's Avatar
Ill try to be as descriptive as possible with this, a few weekends ago i took a perfectly working 13b and swapped it into my fc that had a blown coolant seal. As far i could tell i swapped every thing properly, i got the engine running fine it idles right were it should. I problem is when i try to accelerate quickly the car sputter if that makes any since . it will rev then sputter then rev a lil bit more and sputter again. this only happens when i try to accelerate quickly. if i give it gas slowly while in neutral it will go all the way to redline with out any problems, i have tried everything that i can think of. timing, tps, bac valve, acv, checked for grounds and all my connections and vacuum lines.
Old Mar 23, 2010 | 10:14 PM
farberio's Avatar
NASA-MW ST4
Let me guess, this happens at around 3500 RPM?
This can be caused by poor grounds, or stuck 5/6 ports.
Old Mar 24, 2010 | 11:09 PM
c.gordon's Avatar
i have a similar problem but only happens before it hits normal operating temps. would like to know what it is
Old Mar 27, 2010 | 12:27 AM
calpatriot's Avatar
1. Check for trouble codes. Google 'check RX7 86 88 trouble codes'
2. Check for closed loop operation. Seach this forum for my posts on 'green lamp check'
3. Disconnect the TPS and see if it runs any better without it.
4. Disconnect the TPS and check for proper resistance (see FSM) and no dropouts through its range
5. Set idle, idle mixture, and adjust the TPS.
6. Check the air meter.
if none of that gets it...
7. Check fuel pressure per FSM procedure: at idle, under heavy throttle, static pressure (no flow), and leakdown. Fuel pressure test set at Harbor Freight, $18
8. Pull up the right hand carpet; get access to the ECU. Backprobe each pin on the three connectors with a voltmeter. Check each voltage with the ignition on but not running, then do it again with the car idling. compare the values against the table in the online FSM. A bad sensor or wire will show up as a voltage well out of the normal ranges published in the manual.
Old Mar 28, 2010 | 06:23 PM
atc_rider89's Avatar
i just bought a 88 with a 13BT... it sat for 2 yrs.... i changed oil.. plugs wires... it started up and obviously smoked for a lil while but ran decently good.... i drove it for bout 2 or 3 days maybe put 200 miles on it..... i statred it up one morning let it set for bout 10 min got bout mile down the road and lost all power.....i can punch it and it will move but very slowly... idk whats wrong.... its starts fine but wont go... i cheaked all plugs, wires, spark..... but still cant find nothen... any ideas?
Old Mar 28, 2010 | 06:25 PM
farberio's Avatar
NASA-MW ST4
^ Do a compression test. Be sure you are doing it the right way.
Old Mar 28, 2010 | 06:28 PM
do u kno what it should be at? and if its not at whatever it should be i will need new seals?
hotshot2014
Jul 18, 2017 02:30 PM
immanuel__7
Canadian Forum
Sep 2, 2015 08:26 AM
gtcd
30
Aug 19, 2015 02:44 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
ncds_fc
Aug 15, 2015 10:06 AM
