Those with feed sideskirts... question about mounting.
Old Mar 18, 2010 | 07:44 PM
Viking War Hammer's Avatar
*** Bless The USA
Cool Those with feed sideskirts... question about mounting.
It's probably been asked a million times, so sorry.
I see alot of you are using self tapping screws. Are you pre-drilling the body?
Old Mar 18, 2010 | 08:18 PM
MOBEONER's Avatar
It's finally reliable
so what this question means? You got an FD now? pics please...
Old Mar 18, 2010 | 08:57 PM
93_fd's Avatar
i predrilled mine. didnt use self tapping.
Old Mar 18, 2010 | 09:21 PM
NoPis10's Avatar
Committee Member #2
I was wondering the same thing...
Old Mar 18, 2010 | 10:04 PM
*** Bless The USA
Old Mar 18, 2010 | 11:29 PM
Chaotic_FC's Avatar
i'd like to see these as well.
Old Mar 19, 2010 | 01:01 AM
fdfreak's Avatar
self tapping a with washer , no pre drilling. Just dont over tighten. I put about 8 screws on each side and its sturdy as hell.
Old Mar 19, 2010 | 09:04 AM
*** Bless The USA
Right on, thanks.
Can a jack be used with these installed?
Old Mar 19, 2010 | 09:50 AM
Battle Cat's Avatar
Space cadet
^ i use a scissor jack because my car is too low for normal jack,, and it clears it
Old Mar 19, 2010 | 09:59 AM
Ceylon's Avatar
Non Runner
I would advise installing them with rivnuts.
Old Mar 19, 2010 | 10:34 AM
impactwrench's Avatar
I can still get a floor jack under them with the car lowered 2".
Old Mar 19, 2010 | 01:05 PM
Islander's Avatar
I used self tapping. And yes the car can be jacked up normally.
Old Mar 19, 2010 | 02:32 PM
_Bahrx7_'s Avatar
can i jack up the car BY the sideskirts?
...kidding.
But could someone please post pics of the said screws/rivets/gum that was used to secure the skirts?
Old Mar 19, 2010 | 04:01 PM
JTurtonRX_7's Avatar
EFR IWG 8374
has anyone mounted em with
im not a fan of drilling holes when its not needed
Old Mar 19, 2010 | 04:49 PM
oo7arkman's Avatar
In the Garage
^^I may use some of that in addition to screw, but I would NEVER mount side skirts with only mounting media/adhesive. A few screw holes that are properly sealed/protected from weather should not hurt anything.
You may predrill a small hole, use a small bit of silicone and then finish screwing the skirts on. But that is just how I would mount em.
Old Mar 19, 2010 | 05:08 PM
MOBEONER's Avatar
i am with you on that one.
I know a guy who installed Turbo II side skirts using double sided tape and has worked wonderfully for quite some time. The only thing that sucks about mounting feed side skirts with tape is the risk factor-Feed side skirt are freaking expensive,don't wanna loose one in the highway.
purerx7's Avatar
Registered User
Tutorial for the install
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/%5Brx7-boutique-tutorial%5D-feed-side-skirts-install-863538/
Old Mar 19, 2010 | 05:18 PM
staticguitar313's Avatar
R.I.P. Icemark
The thought of drilling holes in the bottom of the FD just doesn't sit well with me. I do want these sideskirts really bad though.
Old Mar 23, 2010 | 01:00 PM
Black Magic's Avatar
2355lbs...
i drilled 5/8th holes and welded nuts into my chassis and now i have six 10mm bolts that secure mine to my chassis. they arent budging anytime soon. For the guy that suggested the 3m trim adhesive, i hope you were joking...
Old Mar 24, 2010 | 11:00 AM
Ka Kui's Avatar
Beyond
I saw a post in here before that a FEED side skirt can fit under the OEM mud guards. It is possible right?
Old Mar 25, 2010 | 05:52 PM
*** Bless The USA
How and what is everyone painting theirs with? Textured, Gloss, Flat?
Mine aren't c/f. I was thinking about giving it the same textured coating as my R1 front lip. Not sure what would look good though.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
