idle surging, fuel and oil questions
Old Mar 16, 2010 | 01:13 AM
justanoob's Avatar
Hey guys, i have a 86 2nd gen. that I just got running. I believe the fuel pressure damper was the problem. It runs good, but when at a stop the car seems to be idleing low then high continously.
Anyway I was wondering what is the best gas and oil to put in this beast. Thanks alot
Old Mar 16, 2010 | 02:37 PM
gracer7-rx7's Avatar
needs more track time
Doubtful. The FPD = fuel pulsation dampener. Not fuel pressure damper. If I read your comment correctly, it seems like you are saying that your idle is fluctuating or surging or hunting up and down? Is that right?
As for best gas - use a quality gas.
As for oil - it depends how you use your car but you might want to start by reading the FAQ for past discussion on the topic. I'll let other 2nd guys chime in on that if they want.
Old Mar 16, 2010 | 04:58 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Hunting idle is usually the TPS or a vacuum leak. TPS adjustment: http://howto.globalvicinity.com/gv_w...i=58&co=1&vi=1.
Gas: top tier 87 octane.
Oil: conventional or high-end synthetic. 10W-30 or 10W-40 cover most regions' temperature ranges well.
alphawolff
Nov 17, 2015 05:57 PM
ncds_fc
Aug 15, 2015 10:06 AM
rkhanso
Aug 13, 2015 11:40 AM
