West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Need Urgent Differential Install Help!
Old Mar 13, 2010 | 09:42 PM
Marck's Avatar
Unhappy Need Urgent Differential Install Help!
So me and Rob&FC tried to remove my differential and we are stumped on one part. The three bolts the mount on the differential, we removed them and how do we remove the differential itself out? what are the necessary steps to remove and put it back on? i need to go to school on monday and the bus doesnt sound that awesome. Any help i would aprreciate thanks
Old Mar 13, 2010 | 10:08 PM
Apex944's Avatar
Technician
Seriously?
First go get the FSM from fc3s.org or even a hayne's manual.
If you still can't figure it out do a quick search and i'm sure a ton of thread's will apear about how to remove/install the differential.
Here's some quick spoon feeding for you though-
1. Disconnect driveshshaft
2. Unbolt the half shaft's from the differential
3. 2 stud's with nut's on them on the underside of the car hold the top half of the differential into the car
4. Another brace on the front nose of the differential hold's the front which is the differential mount that is commonly talked about
5. Drop the differential with a floor jack
Now I could drop it and install the other one for you for the cost of fuel plus an hourly road service fee of $97 an hour from the time I leave my shop to the time I finish working on your car. Figure about 1.5 hour's to get to you + 1 hour to drop the differential + 2 hour's to re-install your new differential. Could take longer or less time, depend's on what I run into. Total of around $500 or so
Old Mar 13, 2010 | 10:12 PM
Marck's Avatar
no were just stump because do we have to remove the cross brace? because theres no clearance nor can we even pull of the diff down i mean we can but it wont go all the way through the stud. So basically we got all the studs and nuts out but we cant pull out the diff
Old Mar 13, 2010 | 10:18 PM
Apex944's Avatar
Technician
Yes, it has to be dropped also to give you the clearence for the differential.
Page 9-24 in the FSM Front and Rear Axle manual show's everything that need's to be unbolted to remove the differential.
Old Mar 14, 2010 | 09:29 PM
stormshadow531's Avatar
I break cars.
i believe you can drop the subframe most of the way and slide it out. but you cant do anything if you dont at least loosen it.
Old Mar 14, 2010 | 10:08 PM
iLikeEatPoo's Avatar
The Great Dick
If you want to install it bolt everything back on.
Old Mar 15, 2010 | 12:30 AM
ROB&FC's Avatar
s4 GENERAL
its done. we droped the sub frame a bit, and lots braker bar jobs! lol chirps nice now...
Old Mar 15, 2010 | 12:37 AM
rotary#10's Avatar
Vodak
lol don't have too much fun out there now.
Old Mar 15, 2010 | 12:39 AM
Marck's Avatar
haha ill try not too but it seems like we didnt torque everything to spec hmm
Old Mar 15, 2010 | 12:33 PM
ROB&FC's Avatar
s4 GENERAL
Originally Posted by Renton
yeAH ONE of these lol
http://www.cis.rit.edu/~ejipci/image...0854_small.jpg
dude marck there is no specs on torque on the diff, lol it's tight as **** its a welded they sound like that hehe unless u been sliding allready then you might want to check it out but that **** is on there...
Old Mar 15, 2010 | 10:01 PM
Apex944's Avatar
Technician
Are you ******* kidding me!?
And people wonder why I'm such a dick , it's for reason's like your post that there aren't any torque setting's for the differential that could get somebody hurt.
Go to page 9-47 in the Factory Service Manual in Front and Rear Axle section.
Diff carrier 65-77 Ft/lb
Diff case 54-69 Ft/lb
Diff member 54-69 Ft/lb
Sub link assembly 54-69 Ft/lb
Half shaft's 40-47 Ft/lb
Drive shaft 36-43 Ft/lb
Old Mar 16, 2010 | 12:23 AM
ROB&FC's Avatar
s4 GENERAL
u r a dick! http://nickpoint.files.wordpress.com...trix_punch.jpg
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
t-von
Sep 10, 2015 01:56 PM
kkev.7788
West RX-7 Forum
Sep 2, 2015 02:13 AM
