13bt 1st gen sev NZ
Old Mar 13, 2010 | 04:38 AM
Bridge it baby's Avatar
13bt 1st gen sev NZ
Hey people!
Thought i'd share with you what we here in NZ do with rotaries haha
Turbo conversions have become very popular over the last few years, and i definatly wanted to join in!!
I have a series 3 (gsl-se for you in the states), 1984, had the standard 12a tallport in it when i first got it, ran that for a while, then had that bridgeported, then, it went crazy.
13bt block from a series 6 (batty), to4e turbo, bosch 044 and holley blue pumps, 850/1650cc injectors, -6 and -8 fuel lines throughout, series 5 turbo g'box, hilux diff with 4.3 lsd head, series 6 front calipers with 285mm rotors, series 5 rotors and calipers in the rear, front mount intercooler, 3" piping, full 3" stainless exhaust, 48mm turbosmart wastegate, 14" SPAL radiator fan, gilmore pulleys, blitz BOV, microtech lt10s ECU, custom guages inside... and some other bits and pieces
Heres a few pics...
the 12a bridgy, 48mm IDA
13b block mounted up
FC turbo g'box with g'box with gsl-se shifter to bring gearlever forward
brake caliper mounts
coilovers i made up
intercooler mounted infront of the radiator, with the top panel fitted nobody would know its there
modified FC gearbox cross-member
exhaust manifold tacked up, 2" steampipe bends used
hilux diff mounted up
FC rear rotors and calipers fitted
This build has taken about a year so-far...
more pics to come
Old Mar 13, 2010 | 04:43 AM
3" stainless 'cooler piping, nice and short
lobster-back dump-pipe, going to continue style for the rest of the exhaust system
Fuel system is, complex haha, Have used -6 lines for surge tank feed and all return lines, and -8 for main feed to engine and all injector plumbing
Old Mar 13, 2010 | 04:49 AM
guage panel i made up
removed all unused wiring, there was alot!!
-8 fuel rail i made up for the 1680cc injectors
mallory fuel reg
cut some holes in the fan shroud to allow more air flow, can also see oil cooler mounted below radiator
mounted the 4 bosch coils on the LH strut tower, with 8mm leads
Old Mar 13, 2010 | 04:59 AM
exhaust manifold finished
motor before...
and after paint
This has come a long way!
I started wiring in the ECU today, a Microtech lt10s, wasn't too tricky, just time consuming! Hopefully finish it off tomorrow with any luck. Still have a few bits and pieces to get/do, but its damn close to turning the key!!!
Old Mar 13, 2010 | 05:41 AM
simgabe's Avatar
looking nice, great job.
Old Mar 13, 2010 | 08:13 AM
n0ferz's Avatar
Looks real good, keep up the good work and please post more pics when you can
Old Mar 13, 2010 | 08:26 AM
installer67's Avatar
Dreamin of drivin my 7!
Looks great! I actuaully like the first pick the best. LOL I'm an N/A man.
Old Mar 13, 2010 | 12:02 PM
food7373's Avatar
Kid
They first picture is definitely awesome, but either way, that's a really good looking car and a really good job you did.
Old Mar 13, 2010 | 01:49 PM
yea, i really do miss the 12a bridgy that was so nice to cruise around in but it had alot of pull to! Some BIG flames (15 sec worth alot of the time!!) came out the back with that setup haha looked wicked at night
Even though there is obviously alot more in the engine bay now, i'm trying to keep the similar "clean" look, hence the delooming and not alot of shiney bits and pieces.
Definatly more pics to come
Old Mar 13, 2010 | 03:21 PM
blwfly's Avatar
kiwi from downunder..
nice ride..
kiwi's rule... haha kiddin
Old Mar 13, 2010 | 04:10 PM
bad 83's Avatar
PSHH! PSHH! HEAR ME NOW?
Once you go turbo in a first gen, you never want to go back. Right now, I am a little over 300 rwhp and I want more. Your setup is looking like you should be well over the 300 hp mark. Looking good. Welcome to the turbo FB crew
Old Mar 14, 2010 | 03:43 AM
captainbizzaro's Avatar
What's that smell?
Good work mate, wish I had the same talent for metal fabrication
Old Mar 14, 2010 | 05:27 PM
Jimbo II's Avatar
Rotating
I'm dribbling for this to be going man! Can't wait...
Old Mar 14, 2010 | 05:56 PM
vmarx7@yahoo.com's Avatar
i'm interested in how you have the fuel system set up
looking to do some thing similar
can you pm me with the details?
Old Mar 15, 2010 | 02:56 PM
hoang5659's Avatar
looks like a great project. keep the pictures coming.
Old Mar 15, 2010 | 05:46 PM
buldozr's Avatar
Perk adds +20% to boost
The holley blue pumps are internally regulated at 14 psi, any higher pressure at the rail will cause the pump to just bypass it.... GET RID OF THOSE BLUES!!! You need atleast 25psi fuel pressure to get the injector to atomize right and that is a bare minimum. Blue pumps are for carbs, not FI. I recommend a external walbro or bosch pump. GL.
Old Mar 16, 2010 | 03:41 AM
Umm, ok? i'm using the holley to fill the the SURGE TANK, not as a main feed. I have a bosch 044 as the main pump...
that calmed you down a bit??
Old Mar 16, 2010 | 04:14 AM
tasty danish's Avatar
Doesn't suck
I want to mouth-ify your engine bay
Old Mar 16, 2010 | 06:11 AM
Dan_s_young's Avatar
Turbo widebody FB
Looking good, similar mods as I have done with my car. Looking forward to seeing what kind of numbers your setup makes, and maybe some videos of it!
Old Mar 16, 2010 | 06:37 AM
mikeric's Avatar
FB=OS Giken LSD
Very nice. I liked the brake upgrade keeping the 4 studs.
Great work! Send us some dyno numbers.
Kiwis do rule. Now I have one more reason to visit NZ.
Old Mar 17, 2010 | 01:52 AM
Ok, heres how my system is set up, except I have a holley blue instead of a carter black.
Have got -8 lines from the srurge tank to the fuel reg, all other lines are -6
Old Mar 17, 2010 | 05:45 PM
buldozr's Avatar
Nice, I am calm now. My first impression was that you were going from carb to FI and trying to swing using the carb pump. Interesting fuel system setup though, a little excessive but overkill is a good thing
Old Mar 18, 2010 | 12:05 AM
jay85gs's Avatar
4x110 SUCKS!
Beautiful Job
Great work, top notch my friend........Very Very Clean.........Can eat off that engine bay!!!!!!!!
Old Mar 18, 2010 | 05:42 PM
haha cheers guys, definatly wanted to have a clean simple (i'm TRYING!! alot to squeeze in!!) engine bay, love the look.
Yea i've built the fuel system as an overkill, much rather have too much fuel than too little
Pretty much the list left to go is
1. build up bigger turbo drain
2. get computer back from Microtech (being mapped for my motor)
3. hose clamps on bottom radiator hose
4. build up remaining exhaust system (going to start it without thu )
5. connect up wiring for the eletronic guages.
6. turn key and hope i've timed it right!! haha
Old Mar 19, 2010 | 03:11 AM
Well, sorted out the wiring for the engine ECU last weekend, wasn't overly hard at all, just time consuming! haha The loom was all labelled and the instructions were very simple to follow. I mounted the ecu and ignitor on the passenger-side footwell, where the factory cruise control and emission controllers were, under the steel cover, nice and protected, perfect fit!
Heres some pics.
end result, nice and tidy
