keep loosing clutch fluid
Old Mar 11, 2010 | 09:47 PM
valleyroger's Avatar
Keep loosing clutch fluid on my 87 GLX. The steel line is good, put a new flex hose on, the slave cyl looks dry. Wondering if the clutch master could be leaking inside the cowel (between the inside and outside of the firewall??? Any body hear of this happening before??
Old Mar 11, 2010 | 10:04 PM
RotaryRocket88's Avatar
Top Down, Boost Up
It's possible for the master cylinder to leak into the passenger compartment. Stick your head up underneath the dash and look for fluid around the firewall.
Old Mar 11, 2010 | 10:16 PM
I got no visible fluid inside under the dash or under the hood. I can't see it leaking any where.
Old Mar 11, 2010 | 11:02 PM
ffilemyr's Avatar
FFilemyr
look on the top of the trans from the drivers side check the slave cylinder
find the master cylinder follow hose to slave cylinder i just had to replace mine due to a bad seal. i was losing fluid then it just stop working
Old Mar 11, 2010 | 11:05 PM
Top Down, Boost Up
It has to be going somewhere. If there's nothing visible in the engine bay or by the pedals, you might have to remove the master cylinder to spot it.
Old Mar 12, 2010 | 05:53 AM
AcidShock's Avatar
Eet fase
Somtimes you cannot easily tell if it is leaking into the interior as well. That fluid easily gets soaked up by the sound deadending material pasted against the firewall. Sometimes you have to pull it back to discover that it is wet or discolored from the brake fluid.
Old Mar 12, 2010 | 07:28 AM
AcidShock you were right. Pulled the clutch master out this morning and the foam inside there was soaked with fluid.
Old Mar 22, 2010 | 03:32 PM
The Chazz's Avatar
Glad you figured it out, had this happen to me before and it actually turned out to be the clutch master as well.
Hipsiguy
Sep 14, 2015 05:25 PM
Evan Kurtz
Sep 13, 2015 08:40 PM
