Power FC New M&W CDI with the PFC in mind
Old Mar 11, 2010 | 04:43 PM
C. Ludwig's Avatar
www.lms-efi.com
Just got confirmation that M&W has a new box, which is labeled the Pro 14R V2. The V2 is specifically designed for 3-channel ECUs like the PFC. This box will do true 4 channel, direct-fire output with only the 3 channel, wastespark input. I don't have the specifics on how it operates but I'm guessing it references the T1 input and knows the firing order after will then be L2, T2, L1. So, with the V2 box, leading will not fire in wastespark as they do when the regular Pro 14R is installed on a 3-channel ECU, but in direct-fire, spark per revolution mode.
Not sure there is a real benefit to running direct-fire v. wastespark with CDI. It's not like an inductive system where duty cycle becomes a concern at high revs. It would obviously allow the leading coils to operate at half the duty and maybe help with any potential heat issues on extended duty circuit applications.
Old Mar 11, 2010 | 05:00 PM
Blackadde///'s Avatar
20b GTX4294R MS Dry-Sump
ludwig.. which CDI would you run with the PS1000 and/or PS2000 on a 13b?
Old Mar 11, 2010 | 08:11 PM
thewird's Avatar
Might be getting this ^_^
thewird
Old Mar 12, 2010 | 05:43 AM
C. Ludwig's Avatar
www.lms-efi.com
I like the M&W. They work well and are reliable. They're also 4-channel capable in a single box that is smaller than any of the single MSD boxes. You'll need 2+ MSD boxes to build a similar 4-channel system and packaging that on a street car gets to be a real pain.
Old Apr 25, 2010 | 03:27 PM
remydrm's Avatar
ROTARY POWER
CA
Where do you guys recommend by the M&W cdi units? Are any of the forum vendors carrying these products?
Old Apr 25, 2010 | 04:05 PM
thewird's Avatar
Ludwig sells them.
thewird
Old May 3, 2010 | 06:31 PM
rico007's Avatar
La FIEBRE
nice units tiny as hell i got mine from C.LUDWIG great vendor man.
Old Jan 8, 2014 | 12:44 AM
red 7's Avatar
Do any of the M&W come with a 2-step?
Old Jan 8, 2014 | 12:01 PM
C. Ludwig's Avatar
www.lms-efi.com
No they do not.
Einheri
Oct 7, 2015 12:23 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
