need desperate help
Old Mar 10, 2010 | 11:04 AM
alluknoskill0000's Avatar
CA need desperate help
hi everyone,
Here's the problem, I have an NA 5 speed 87 rx7 that's been sitting for some time now and I've been away for the past several months. Now I'm back and I wanna get the car running again but I'm clueless on where to start and what needs to be fixed. Can you guys give me some help out. Any help and advice would be gratefully appreciated. The battery is not the problem bc I've already changed it. The car is completely stock.
Thanks for reading and sharing your ideas,
-jimmy
Old Mar 11, 2010 | 07:01 PM
RotaryRocket88's Avatar
Top Down, Boost Up
What's the problem?
http://www.aaroncake.net/rx-7/unstore.htm
Old Mar 12, 2010 | 02:28 PM
mazdarotaryfan's Avatar
so, what problems are you having with it? wont start? does it turn when you move the key to start?
Old Mar 13, 2010 | 02:13 AM
hi, when i turn the key theres no click coming from the engine and nothing starts up. all the electrical components are on. i was planning on changing the spark plugs but im a bit confused about the trailing and leading plugs, what is the difference? how would i change the plugs?
Old Mar 13, 2010 | 09:36 AM
88rx7gxlturbo's Avatar
Most likely:
* Battery needs charging.
* Battery needs replacing.
* Cable is loose.
* Starter is bad.
Those would be a place to start.
Old Mar 22, 2010 | 08:42 PM
Sorry for the late response.
So far I've tired to charge the battery but the car didn't get a crank. the first time I try to start the car I heard clicks from the engine but no start. Try turning tghe ignition again, no clciks this time. Do you guys think battery is dead?
Also, I've tried removing the sparks plugs to clean em but didn't have the right size wrench would you guys knowwhat size it mights be?
Should I consider changing the starter?
Old Mar 23, 2010 | 12:36 AM
canonize-ryda's Avatar
ive had a problem were it wont start after sitting for 5 minutes and i simply wiggle the power cable on the battery and try starting and bam. but in your case i check to make shure the battery has enough charge and if it just clicks make sure its getting fuel. if you have new battery and still no good starter may need to be wedged or replaced.
Old Mar 23, 2010 | 08:14 AM
warlock78's Avatar
try giving the starter solanoid a decent tap with a hammer while someone cranks the car over a go. wont fix ya problem, but if it starts you'll what the problem is!!
Old Mar 25, 2010 | 03:07 PM
thanks everyone,
i finally got my car to start, turns out it was only the charge.
however ive encountered another problem now, once the car starts and i rev it up a little the engine shuts off. anything i should be worried about?
Old Mar 25, 2010 | 07:20 PM
hi
bad news, my car doesnt start again. it was running for a while earlier and after warming it up, i shut it off. now the car wont start again when i was planning to take it for a drive. i replaced the battery in there. i noticed that one of the spark plug coil was off and i plugged that back in and still doesnt start. could the alternator be broken? any suggestions to what might be broken?
Old Mar 25, 2010 | 08:15 PM
RXnos1200's Avatar
1200 gone......but......
doesn't start again? So are you talking about the starter cranking over or the engine firing up?
Old Mar 26, 2010 | 12:19 PM
Top Down, Boost Up
Definitely specify whether or not the starter is able to spin when you turn the key. "Won't start" can mean a lot of things. If the starter is not doing anything when you turn the key, test battery voltage. If it's lower than about 12.5V, it's not fully charged. If that's the case, check the positive connection on the alternator post, the main ground on the transmission bell housing & the positive lead on the starter itself. Charge the battery and start the car. Put a multimeter on the negative battery post and the alternator post and read the voltage output. Ideally this will be around 14V. If not, the alternator may be toast.
Lou Byer
20
Oct 12, 2020 08:03 PM
Aramir
Oct 18, 2015 02:39 AM
portugueserotary
NE RX-7 Forum
Oct 4, 2015 08:30 PM
MikeTee55
Sep 8, 2015 08:05 PM
