Power FC buy a commander or not?
Old Mar 5, 2010 | 03:56 AM
douwe's Avatar
i have a Apexi power fc in my car i am going to get a datalogit for tuning as i am going single soon. hand commanders are worth $600 and i can buy a new 10' laptop for less and dedicate it to my car or do i really need a hand commander?
thanks
Old Mar 5, 2010 | 08:05 AM
C. Ludwig's Avatar
www.lms-efi.com
IMO absolutely not. As long as you have the Datalogit, the Commander is simply a gee whiz decoration.
Old Mar 5, 2010 | 02:50 PM
douwe's Avatar
thanks i will spend the money on a new laptop also does datalogit work on win 7 fine?
Old Mar 6, 2010 | 10:20 AM
thewird's Avatar
Commander is nice to monitor temperatures etc. Pretty sure you can get a commander for a lot less then $600
thewird
Old Mar 6, 2010 | 10:39 AM
fd_neal's Avatar
When I had PFC I had datalogit and the commander. I ONLY used the commander for monitoring while at the track, other than that its pretty useless. Setting up a 10" laptop or netbook in the car would be much more challenging for quick referencing.
I would look for a good price on a used one, and use it as a gauge.
Old Mar 6, 2010 | 12:15 PM
arghx's Avatar
rotorhead
I have a Datalogit but I use my Commander frequently, especially when I don't feel like breaking out the laptop for some minor change. It is my sole boost gauge in the car (I got tired of having multiple boost displays that didn't agree). I check the air and water temps on it all the time. I use the peak-hold function to display peak boost, rpm, and sometimes knock after a WOT run. I control boost with the PFC so I switch boost levels with that. I may also make small adjustments to warmup AFR's and cranking/warmup timing as the weather changes, or small idle speed changes if I am fiddling with that.
If you are going to take it to someone for tuning and won't be regularly monitoring the car's behavior yourself then I would only get one if you find a good deal. Having a laptop running every time you drive is a pain. You feel like you are launching a spaceship every time you go to 7 eleven.
Old Mar 6, 2010 | 06:23 PM
douwe's Avatar
if i find one cheap i will get it, they aren't the easiest thing to buy second hand. thanks for your input
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
jdayau
Nov 29, 2019 12:11 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
mulcryant
Sep 9, 2015 05:24 PM
