Microtech No RPM sig and error
Old Mar 2, 2010 | 03:32 AM
TURSTY's Avatar
The wankel way!!
Just installed a MT10s into my FD and powered everything up
Other then an incorrectly adjusted TPS, every sensor is reading correctly and is working well, fuel pumps priming correctly etc.
However, it has an error saying RPM. It had this right from when I connected the laptop and connected to the ECU. It also gets no RPM signal when cranking.
I have tripple checked the wireing to the crank sensors, and have checked continuity from plug to plug.
I cant try and start the car as the coils and turbo are not on the car....but is should still get signal at cranking correct?
Am I missing something here?
Old Mar 3, 2010 | 05:13 PM
rx72c's Avatar
Top Answer: 1
Please tell me how you have wired up your crank sensors.
Also check to see if you have a crank signal without the laptop connected by looking at the orange light on the ecu.
Check to see if it flashes while cranking.
Old Mar 3, 2010 | 06:20 PM
TURSTY's Avatar
The wankel way!!
Problem solved
Was just bad earthing. Wire brush and contact cleaner to all major earth points and all is well.
It now gets a amber ligh pulse when cranking, doesnt read any RPM but after speaking to microtech, it wont read anything under 500RPM.
It now changes status from cranking to "." which is normal.
It still throws an RPM error after extended cranking - but according to microtech, this is normal as well.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
eplusz
15
Oct 7, 2015 04:04 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
musker
Oct 1, 2015 05:58 PM
