Megasquirt rev limiter question
Old Mar 1, 2010 | 08:32 PM
chango de naranjito's Avatar
Why if I set the rev limiter to spark cut,retard, in fc mode, it only cuts the leading spark? if I set it to rx8 mode it will cut leading and trailing?
thanks, Frank
Old Mar 1, 2010 | 09:53 PM
muythaibxr's Avatar
MegaSquirt Mod
You must be using an older version of the firmware?
I believe in newer versions (not sure if this made it into 2.1.0d or not, I have not looked at it in a while, but it should be in 3.0.3r) of the firmware, it turns off trailing completely.
Ken
Old Mar 2, 2010 | 04:52 PM
Ken
I am using 3.0.3q thats why?
Old Mar 2, 2010 | 07:49 PM
I test it with the stim and with the 3.0.3r only cuts the leading too any idea?
Old Mar 3, 2010 | 10:49 AM
muythaibxr's Avatar
MegaSquirt Mod
Somebody must've broken it in the alpha firmware. I'll have to take a look and fix it.
Ken
Old Mar 3, 2010 | 08:12 PM
Ken
gracias!!!!!!!!! thank you so muuuuuuch!!!!
Old Mar 5, 2010 | 08:51 AM
Ken
I test all the codes today and they all have the same problem and use fd an rx8 mode as well and all have the same problem
Old Mar 5, 2010 | 12:45 PM
muythaibxr's Avatar
MegaSquirt Mod
I wonder if I only fixed this in ms3 and didn't backport it. In any case I'll fix it.
Ken
Old Mar 5, 2010 | 08:58 PM
Ken
muchas gracias amigo!!!!!!
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
13
Jan 9, 2018 11:19 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
83revival
Sep 3, 2015 10:42 PM
