newbie idle probs
Old Feb 24, 2010 | 02:55 PM
datz's Avatar
GNARKILL
AZ newbie idle probs
i have a 1990 GXL with 85xxx miles, when i start it in the morning(cold start) it idles at 3k for about 10 secs, then slowly drops down to 2300 rpm, then very slowly drops to 1600 rpm(this very slow drop takes about2-3 mins, then i let the car idle for almost 20 mins, it warms to opp temp in probly 10 min after starting but wont go below 1600 rpm.
right now i have the dashpot out for easier acces to the fast idle cam, ect. when i look with a loittle mirror the fast idle roller HAS seperated from the cam, so i try to push the roller down, it goes nowhere.
when i put load on the engine, headlights, ac, ect. the rpms increase slightly like they should.
when i drive the car, somtimes at red lights the idle will drop to 600 rpm then evenly and uniformly bounces from 600 to 900 rpm. but most of the time the rpms stay near 1600.
ADVICE PLEASE
Old Feb 24, 2010 | 06:30 PM
datz's Avatar
GNARKILL
AZ
sorry for multiple post but i just noticed it says "exhaust leak" under my name when i post. i never entered that text. does it change according to how many post i have?
Old Feb 24, 2010 | 07:28 PM
blandino5150's Avatar
I Gotta 7 Fetish
u can change exhaust leak in the user cp
Old Feb 25, 2010 | 04:03 AM
datz's Avatar
GNARKILL
AZ
thanx man, but the real prob im focused on is my cars idle. the "exhaust leak" was just "how the **** and why the ****"
Old Feb 25, 2010 | 10:15 AM
smwebb's Avatar
could be a funny ground somewhere if the fast idle wont fix it. my turbo will idle high until i hold clutch and put it in gear then it will drop and stay there. and somtimes will do the surge **** like alot do. sometimes they just have crazy idles
Old Feb 25, 2010 | 12:07 PM
datz's Avatar
GNARKILL
AZ
ya it drops when i put it in gear and not move
Old Feb 26, 2010 | 04:52 PM
driften16's Avatar
this sounds like almost the same problem i am having with mine ...ive been playing around with it too since im a newb to the rotary myself..tell me though does the idle go down when you push the tps in a lil?
Old Feb 26, 2010 | 06:07 PM
datz's Avatar
GNARKILL
AZ
my new tps should be here tomorow so i havent tried that, but its easy enough so ill try it
Old Feb 26, 2010 | 07:14 PM
datz's Avatar
GNARKILL
AZ
i tried depressing the narrow range tps while at idle
it did nothing untill i depressed it about half the way, then the rpms droped but it uniformaly bounced about 200 rpms
i am thinking the new tps and a new bac(when i get one) should fix that prob. cause just about everthing else checks out fine.
Old Feb 26, 2010 | 08:06 PM
TheRotaryGF's Avatar
My RX-7 rev's up to 3000 RPM every time I start it when cold
Yep, part of the accelerated warm up process. Start the car with the clutch pressed in, and the car in gear if you don't want it to do that.
^ Found this in the Gen Specific FAQ, remembered seeing something on it yesterday. Below is a link to the page for your reference.
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/frequently-asked-questions-2nd-generation-rx-7-faq-fc-494667/
Old Feb 26, 2010 | 08:22 PM
datz's Avatar
GNARKILL
hey thanx alot!
Old Mar 1, 2010 | 07:39 PM
smokimon001's Avatar
Rotary Spirit
i have teh same problem, had been tried everythig else, looked for vaccum leak, cleaned throttle body, tested and cleaned air by pass valve, found out the resistant of my tps isnt right, so i am looking to buy one and have my replaced. hope that solve my problem.
Old Mar 2, 2010 | 02:55 PM
smwebb's Avatar
^could be. mine does similar thing but not as bad and i know my tps is bad already
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
