Removing the steering wheel...
Old Feb 23, 2010 | 10:33 PM
elmayimbe4eva27's Avatar
Hello, i am trying to remove my steering wheel and i know you must use a puller. I bought one online from Sears but when i received it, none of the supplied screws fit the holes. Does anyone know what are the correct measurements for the steering wheel and screws, and possibly where i can find extra puller screws? Thanks!
Old Feb 24, 2010 | 10:53 AM
Aaron Cake's Avatar
Engine, Not Motor
Put a pillow between your face and the steering wheel. Grab the wheel firmly with both hands and then rock it back and forth while pulling as hard as you can. I have never seen one stuck enough to require the use of a puller. Just BE CAREFUL otherwise you will punch yourself in the face.
Old Feb 24, 2010 | 11:44 AM
RTRx7's Avatar
Rammer Jammer
You could leave the nut on there a little bit also.
Old Feb 24, 2010 | 12:05 PM
84stock's Avatar
YES!!! LEAVE THE NUT ON A FEW THREADS SO YOU DON'T GET A MOUTHFUL OF STEERING WHEEL!!!
You should be able to rock and pull it off, try a little (very little) bit of penetrating oil on the shaft.
Old Feb 24, 2010 | 01:32 PM
Aaron Cake's Avatar
Engine, Not Motor
...But the pillow is so dramatic!
Old Feb 24, 2010 | 02:36 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Sometimes they can really get stuck so badly that a puller is needed. The first time I pulled mine by rocking it (and not smacking myself in the face), but recently I tried to take it off again, and damn it is really on there. A good 10 minutes worth of pulling, rocking, and hitting it w/ a dead-blow hammer, and I gave up. Auto parts store will rent pullers out too if needed (basically for free).
Old Feb 24, 2010 | 04:33 PM
Cool. i'll try not to smack myself in the face with the wheel, if i do, i'll post some pics up so you all can get a good laugh. :-D
Old Feb 25, 2010 | 11:44 AM
Turbo8's Avatar
REPU Garage
Just thread the nut back on a few threads to prevent facial injury.
Depending on what car you have, I would avoid using any type of hammer as some of the steering shafts are meant to collapse and with a hammer you could collapse part of the shaft. I believe this is only on 3rd Gens, however.
Old Feb 25, 2010 | 06:52 PM
84stock's Avatar
The steering shaft has 2 "plastic" pins which will easily snap if you beat on the column with a hammer.
Old Feb 25, 2010 | 08:50 PM
Top Down, Boost Up
Is anyone dumb enough to hit the steering column with a hammer? That would accomplish nothing. I was talking about hitting the back side of the wheel to pop it forward. And for the record, it does not work.
Old Feb 25, 2010 | 11:32 PM
RTRx7's Avatar
Rammer Jammer
Did you remember where you're posting?
Old Feb 25, 2010 | 11:45 PM
Top Down, Boost Up
Call me optimistic...
Just clarifying that hitting the steering column, dash, fenders, or random pedestrians will NOT help remove a steering wheel.
Old Feb 25, 2010 | 11:52 PM
RTRx7's Avatar
Rammer Jammer
Point taken..
Old Feb 28, 2010 | 02:30 PM
zracin's Avatar
2 stroke oil
ill be doing this soon as well. thanks
Old Feb 28, 2010 | 02:31 PM
zracin's Avatar
2 stroke oil
anyone have opinions on brands of steering wheels/quickrelease hubs? Im thinking one of the NRG sets on eBay
Old Feb 28, 2010 | 03:11 PM
infernal's Avatar
I'm in the process of installing an aftermarket steering wheel in my FC... Just waiting for the hub.
I'm planning to make a detailed description with pictures on how to remove the wheel and install the aftermarket one, plus what you need to do this.
Where should I create the topic? In the Technical Section of 2nd Gens?
If everything will run as expected, it should be ready before the end of the week.
Old Mar 5, 2010 | 02:44 PM
infernal's Avatar
The tutorial, as promised!
Remove Steering Wheel w/ photozz
Old Mar 5, 2010 | 03:57 PM
hioctane-dtc's Avatar
I thought about getting the quick-release hub in the past, but then I have my car as a daily street car, therefore I felt it wasn't necessary.
Get Nardi if you can find it from the stores near where you live, or order from the net. eBay stuff is.... just decent enough if you don't intent on spending too much money.
Old Mar 5, 2010 | 04:08 PM
TEAM REGIMENT ZERO's Avatar
if you are a big bone i suggest you get the short hubb,gives you more room.
risingsunroof82
Sep 7, 2015 01:11 PM
