oil fill tube milky crap????
Old Feb 23, 2010 | 09:06 PM
chobotRX7's Avatar
ROAD RACING RULES
Unhappy oil fill tube milky crap????
hi i got 12 a and got some milky oil in the fill up tube for oil. there is no coolant in the motor oil and there is not oil in the coolant is it normal just evaporating thru temperature changes ?????? the motor gots very good compretion . and the milky crap is only towart the top of the fill up tube thanks who ever know what it is
Old Feb 23, 2010 | 10:08 PM
Siraniko's Avatar
RX for fun
drill a hole on your oil cap and install a 90 degree fitting.
Old Feb 24, 2010 | 09:23 AM
rdahm's Avatar
TurboRX7.com
I know you said you dont have milky stuff in your coolant, but do you have any stuff in your coolant reservoir? I had both, and a slight leak in a new coolant seal. Not that your problem is that :-) Just reflecting on my own experiences.
I have seen the same stuff collect since then in my oil, but i dismissed it as remnants of the previous failure.
Old Feb 24, 2010 | 10:28 AM
Kentetsu's Avatar
Go to the 1st gen section, and search for the term "lung mustard".
Old Feb 24, 2010 | 10:48 AM
Aaron Cake's Avatar
Engine, Not Motor
Test your PCV system.
And if you are constantly making only short trips with this car, that gunk will build up.
Old Feb 24, 2010 | 06:28 PM
chobotRX7's Avatar
ROAD RACING RULES
Thumbs up thanks
thanks for the info guys i do not have any milky crap in the coolant botle and the car is running about 20-50 miles a day i will try the 90 de grease elbow on top of the oil cap thanks again everybody Marek
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
