That didnt take long , blown coolant seal !!!
Old Feb 23, 2010 | 03:23 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
dont even think i left drive of shop , from getting waste gate ported and f m i c ,done .. overheating , losing water ,bubbleing from rad . and white ex . . still hauls *** and starts right up .now i drive it like i stole it . til it dies !!should just kept my na........10mm
Old Feb 23, 2010 | 03:31 PM
thejallenator's Avatar
man sucks to hear :/ just get a shortblock and swap it in
Old Feb 23, 2010 | 04:02 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
the white smoke might just be regular steam and i cant smell coolant out *** end .........where do i get short block .?10mm
Old Feb 23, 2010 | 04:37 PM
well when my coolant seal went it was white smoke like crazy and compression in teh oil.
as for rinding a short block you'll just have to find someone that has one. or just pick up a rebuild kit from atkins. i think its like 1000 or so for bearings and seals.
Old Feb 23, 2010 | 05:10 PM
Nick_d_TII's Avatar
How many miles on the engine? Open the rad cap and fire it up, if it shoots out like 3-6 ft it's definitely the coolant seal.
Short block? in good condition.. Good luck.
You could do a budget rebuild (bring the flames) and tear down the entire motor and measure everything and buy only what you NEED. And you could probably do it for less than 1k if your engine doesn't have +200k miles on it...
12mm......
Old Feb 23, 2010 | 06:14 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
150k .... found long block 250 bux ...unknown miles .no water in oil .. bubbles like crazy.........10mm.........over heats , then doesnt . no external leaks
Old Feb 23, 2010 | 07:07 PM
Nick_d_TII's Avatar
My Coolant rings went at around 107k or so. You gotta question what condition a engine is in when it has just been sitting. If an engine has blown coolant rings and gets water into the combustion chamber and it sits for a while like that can trash the insides of the engine...
I wouldn't buy an unknown milage motor unless you know it runs good and has good compression, even then your crossing your fingers. I'd say you're better off rebuilding what you already have but that's just my 2 cents...
Good luck... 9mm.....
Old Feb 23, 2010 | 07:56 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
8 mm . . ok . for 1 my 240 hp .10 psi ,, will blow that *** r too......is jinx in jail ?? havent heard a word.. ill still smoke his ***... with blown seal .mabey i buy a bike//wife hates me and 7 . btw , im not pullin motor til it goes BOOM. 7 mm
Old Feb 23, 2010 | 10:01 PM
RW-7's Avatar
Moderating the Trochoid
10mm, I would like to see a dyno sheet proving the 240 horse power you are claiming. It may feel like it to you, but its probably much less. You should come to the next Dyno Day and we can find out what your super seven is really putting out.
Old Feb 23, 2010 | 10:24 PM
blwfly's Avatar
kiwi from downunder..
why not rebuild it before its toast if it has good compression soft seals are only 100-150
Old Feb 24, 2010 | 01:53 AM
jinxed4dub's Avatar
don't blow it up if its just the coolant seals rebuild it., told you not to let kids borrow your car for 2 months. thats what took so long to get turbo off, you can't do that when your racing all the other kids in town..
No I'm not dead, just been working on keeping my T2 running. got new tranny today, feels much tighter than the current one. every gear rolls smooth. can't wait to get this thing in. but I have to pull my PS first.... lots of work to do this week. I'll paypals you that 30 bucks friday evening, or I can come to salem next week and help you pull your motor for the cash? eaither way. at least its just a coolant seal. btw don't overheat your motor anymore, it warps aluminum meaning your intake and rotor housings, possably rotors. but chances are somthing will fail first. also excess heat causes detonation. I also need to install my temp guage.
Old Feb 24, 2010 | 03:31 AM
Derekcat's Avatar
Rotary Zealot!
Don't break stuff to break stuff, that's stupid. You'll be buying a lot more than just coolant seals if you're overheating it...
Old Feb 24, 2010 | 11:01 AM
barney1omm's Avatar
STEP ASIDE !!!!!!!
Alright . Ill save the rest of the motor .. If i put coolant seals in . Do i do apex seals too ? Wat about buyin a rebuilt short block ?5 mm
Old Feb 24, 2010 | 01:08 PM
jinxed4dub's Avatar
if there still in spec they can be reused. when I replace mine I was thinking about ALS seals. I guess there supose to not brake, just bend causing less damage to you internals. they can be straitend and reused is the word on the street also.
Old Mar 2, 2010 | 11:17 AM
barney1omm's Avatar
STEP ASIDE !!!!!!!
I might have jumped the gun ,, rad. Might be pluged , white smok just fuel .and or water pump . Im changin all 2 day .... Im crossin fingers . 10mm hopefully .
Old Mar 2, 2010 | 07:00 PM
jinxed4dub's Avatar
if your getting tons of white smoke from your exhaust its coolant seals, but if its coming from engine bay it would be somthing else. I'd check the turbo coolant lines, and the intake to turbo coolant line might be dripping. I've had that issue. waterpump would be leaking from pully area.
Old Mar 2, 2010 | 09:00 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
1 puff white smok when start , fuel .................. over heats and bubbles big time......................? they gave me wrong water pump . and i changed rad , be in touch ' slow pok jinx
Old Mar 2, 2010 | 09:01 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
o yeah .... no exteral leaks
Old Mar 3, 2010 | 04:49 PM
jinxed4dub's Avatar
yeah, part stores are notorious for giving wrong parts, and rotary parts are even worse. I'm gonna go up and ask if they can get my some new valves and see what they give me. bet you they sell me a valve.
stop overheating it or it will blow up. keep an eye on that gauge, never let it get half way up. should be less than a third. mine sits under 1/4 most of the time. boost and temp are your two main concerns, and don't run out of gas. hitting boost at E is dangerous.
Old Mar 3, 2010 | 06:53 PM
dtale15's Avatar
LOL. i do that shi7 everyday!! jk
Old Mar 3, 2010 | 09:56 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
i got diff . rad . and right water pump in now . ... ill try her out thurs . noon ish . pray for me ... 7mm
Old Mar 3, 2010 | 10:06 PM
installer67's Avatar
Dreamin of drivin my 7!
Yea, though we drive through the valley of domestics
We shall fear no pistons.
For we have the highest redline in the valley!
Old Mar 4, 2010 | 06:51 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
Still over heats ...................................... Wtf
Old Mar 4, 2010 | 07:23 PM
jinxed4dub's Avatar
thermistat? buy an oem one though, cost about 22 bucks, but they last. the stant sucks only lasted like 4 months. started overheating suddenly.
Old Mar 5, 2010 | 09:21 AM
blwfly's Avatar
i dont know if its mentioned but take the radiator cap off when its running and if its bubling and building up it can indicate blown coolent seals to as combution gas's go into the coolent system
