how much boost is to much.
Old Feb 20, 2010 | 12:37 AM
goose415's Avatar
Drift Happens
hey i found a s4 turbo II engine and tranny that comes with everything i need and its from a J-spec website. if i get that engine i wanna pull that turbo and put a bigger one on there and i wanna know how much boost is to much on stock seals. i wanna push 14ish.
Old Feb 20, 2010 | 10:19 AM
Aaron Cake's Avatar
Engine, Not Motor
It has nothing to do with how much boost. It has everything to do with airflow. For example, 14 PSI on the stock turbo is too much (for the turbo) but 14 PSI on a T4B is just starting to wake it up.
How much power do you want to make?
In case you are thinking, no, you cannot run an upgraded turbo on the factory ECU.
Old Feb 22, 2010 | 01:53 PM
goose415's Avatar
Drift Happens
well in my car club there is a 350z i wanna at least hang with and a 94 integra i need to beat and a civic with a type r integra swap. i have a N/A s4 gxl now. and with the way the other cars are built i can stick on the integras bumper but i have to push it hard. i wanna tune my car for drift but keep it on the street so im not gonnaa change camber to much ill just get the adjustables and change them at the track. i already have suspension upgrade. like right now if i have my falken tires i can grip all day but put slicker tires on i slip all day. so to answer your question i want about 250 to 280 horse.
Old Feb 22, 2010 | 07:32 PM
klutchkick's Avatar
nut up or shut up
Not to thread Jack but I've been wondering the same thing. In terms of aftermarket turbo gt30 or so and piggy back or full stand alone. How much psi before damage is done. And very good airflow. Only a few feet of exhaust behind the turbo and def not stock intake
Old Feb 22, 2010 | 08:54 PM
RTRx7's Avatar
Rammer Jammer
You can't get 250whp on the stock turbo.
There are many variations of the gt30. Need to know the other details to be able to give an accurate answer.
Old Feb 22, 2010 | 09:21 PM
klutchkick's Avatar
nut up or shut up
gt3076r can either have .64 or .86 a/r
Old Feb 22, 2010 | 10:05 PM
RTRx7's Avatar
Rammer Jammer
You would be looking at around 350+ hp with supporting mods.
Old Feb 22, 2010 | 10:54 PM
rubenm199253's Avatar
crazyrx7
um bnr???????
Old Feb 22, 2010 | 11:15 PM
goose415's Avatar
Drift Happens
i know i cant i was thinking upgrading to a t4b like aaron said or get a t3. i was just wondering how much boost is to much for the engine when do i need to switch out seals. like i said i wanna hang with a 350z with minor mods (intake and exhaust).
Old Feb 23, 2010 | 10:38 AM
RTRx7's Avatar
Rammer Jammer
You're going to need to have another turbo and the seals you have will do fine. A 350z is heavier but it also has a lot more power. Get a gt35r and call it a day.
Old Feb 23, 2010 | 02:02 PM
Aaron Cake's Avatar
Engine, Not Motor
Sure you can.
Way too small.
If you want to run the 3076, then you should only look at the 1.06 T3 hot side.
Again, boost level is irrelevant. With the 3076, on a 13B, you start pumping heat around 15-16 PSI. So that could be considered your "max boost". However, change the turbo and that number changes.
Seals are fine.
Old Feb 23, 2010 | 02:30 PM
RTRx7's Avatar
Rammer Jammer
What is the element I'm forgetting, aaron?
I thought the stock turbo runs out of gas after about 12psi? I guess you mean with porting?
Old Feb 23, 2010 | 02:54 PM
crazyrx7
this is what aaron means
http://www.bnrturbos.com/2ndGen.htm
getting ports from bnr you can boost alot more with the stock turbo. you can also loook up info here on the forum on bnr ports...
Old Feb 23, 2010 | 03:15 PM
Otaku's Avatar
Herp Derpin
Go bigger....like a T70. If you have the supporting money (which I hope you do considering you plan on going upgraded boost), I'd just go big or go home.
Old Feb 23, 2010 | 06:48 PM
Aaron Cake's Avatar
Engine, Not Motor
You can get 250RWHP without hybrid turbos. An efficient stock turbo setup will do it. A better intercooler, 12-13 PSI of boost, and a good tune.
Old Feb 23, 2010 | 08:35 PM
whitelight7's Avatar
I agree, a good tune (w/ a good ECU) is a requirement before higher boost. There are other important aspects before adding more PSI. First make sure you control boost very well (no spikes, no creep,etc.), control fuel delivery very well, control air and engine temps (never lean out or detonate) - then the rotary can handle more boost for many years. More rotaries/seals blow because they lean out or detonate than from pure PSI. Plan, build, tune, and Hold On!
Old Feb 23, 2010 | 09:41 PM
RTRx7's Avatar
Rammer Jammer
Why are you so high on bnr? You know they have had problems too, right?
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
