Power FC EGI fuse resets PFC settings???
Old Feb 16, 2010 | 05:20 PM
rx927's Avatar
Unhealthy Obsession
I recently found this happening. On a base map but i took out the EGI to deflood went back to the pfc commander and my injectors and other settings went back to stock.
Since the changes i made through the commander were minimal i went back changed them. Took out the EGI fuse again, put it back in and the pfc settings went back to stock again.
Is something up with my wiring/power fc or is this expected and known to happen?
Old Feb 16, 2010 | 05:46 PM
NeoTuri's Avatar
The shy megalomaniac
What happens when you change something from the factory settings and disconnect the battery for a few minutes? If it loses the settings, you may have a problem with the PFC memory.
Old Feb 16, 2010 | 05:57 PM
C. Ludwig's Avatar
www.lms-efi.com
Should not happen. You can unplug the ECU all together and not lose settings.
turbojeff
243
Nov 3, 2018 10:57 AM
torky007
Aug 17, 2015 05:14 PM
