Flat shifting on a rotary.
Old Feb 6, 2010 | 12:14 PM
McCarthy's Avatar
Curious really. Has anyone got a sequential gear set up, 5 or 6 speed, AND running a flat shifting system??? Full throttle gear changes?
I'm told its not as easy to run flat shifting system on the rotaries as it is on a piston lump. Any imput appriciated
Old Feb 6, 2010 | 12:26 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
I dont believe its any different that running one on a piston motor
Racelogic sell's a unit i believe that allows flatshifting on a rotary as well
Old Feb 6, 2010 | 01:01 PM
Mahjik's Avatar
Mr. Links
Arrow
https://www.rx7club.com/race-car-tech-103/t5-dogbox-racing-transmission-install-video-pics-777978/
Old Feb 8, 2010 | 02:41 AM
McCarthy's Avatar
Cheers guys. From what i understood running full throttle gear shifts on the rotaries it could cuase tips to break due to the way the electonics cut the spark to allow the change.
Old Feb 8, 2010 | 01:40 PM
C. Ludwig's Avatar
www.lms-efi.com
You don't necessarily have to use ignition cut. Simply retarding the timing can be enough to hold the revs in check between gear changes.
Old Feb 9, 2010 | 01:01 PM
Silkworm's Avatar
Has been.. hangin' around
oh whoops, should have read closer, I don't think he runs with a flat shift system. Good luck anyway!
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
distr0
Canadian Forum
Oct 7, 2015 08:17 AM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
