I'm wondering if I can swap a 13B turbo engine into my 1981 Rx7?
Old Feb 2, 2010 | 11:32 PM
VxChaosLycanxV's Avatar
I'm looking for engines that I could put into my RX7 and I'm not sure if the 13b-turbo will match up right. If you guys could fill me in, it would be much appreciated.
I'm also a bit of a welder if there are any minor tweaks I'd need to make.
Old Feb 3, 2010 | 06:14 AM
Pele's Avatar
Right near Malloy
There have been many Turbo 13B swaps into the 1st gen RX-7.
You will also need to bring the turbo transmission over.
You can use the 1st gen front cover for mounting.
Old Feb 4, 2010 | 06:33 AM
Viich's Avatar
Migrant Rotorhead
There's a pretty good thread linked in the 1st gen section FAQ.
Old Feb 5, 2010 | 04:28 PM
Thanks, I think I'm just going to stick with my 12A. I was reading a topic that explained switching our the stationary gears and installing an oil pump from a 13B. Later, I might install a turbo, but I'm going to work on what is available to me now.
Old Feb 6, 2010 | 10:52 AM
Aaron Cake's Avatar
Engine, Not Motor
There is no real point swapping the stationary gears or oil pump unless you are putting out some power. A stock port, even a street ported or bridge ported 12A won't make enough power to make that worth it.
Machupicchu
Aug 17, 2015 08:27 PM
ncds_fc
Aug 15, 2015 10:06 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
