Megasquirt Megasquirt + Stock FD REW
Old Feb 1, 2010 | 09:15 PM
RX_Speed_7's Avatar
FB Forever!!!!!
BC Megasquirt + Stock FD REW
ok so I was wondering now to run a Megasquirt on a almost Stock FD REW. the twins have been paralleled, I'm running a modded 12a front cover with an oil line for the twins with a T2 CAS and a GSL-SE oil pan. other then that its stock. its going into a 85 1st gen
can anyone tell me a good way to wire it and a good start up tune?
Old Feb 2, 2010 | 09:12 AM
muythaibxr's Avatar
MegaSquirt Mod
Really you should be able to follow aaron cake's howto at the top of this section.
Old Feb 2, 2010 | 03:20 PM
RX_Speed_7's Avatar
FB Forever!!!!!
the only thing do FD's have a BAC??? and I still need a start up tune
Old Feb 3, 2010 | 12:05 PM
muythaibxr's Avatar
MegaSquirt Mod
I don't know if they have a BAC but I'd assume they have some way to control idle speed.
Ken
Old Feb 3, 2010 | 11:55 PM
ifryrice's Avatar
Sequentially broken
They call it the ISC on FD's, works the same way.
Old Feb 4, 2010 | 10:16 AM
Aaron Cake's Avatar
Engine, Not Motor
The FD BAC is mounted on the bottom of the upper intake manifold. Same settings as FC unit.
The coils are different on the FD so either use 2nd gen ignition coils (better then FD units) or make sure to set "FD trailing" in rotary settings.
Old Feb 4, 2010 | 07:34 PM
muythaibxr's Avatar
MegaSquirt Mod
Yep good advice.
Ken
Old Feb 5, 2010 | 03:25 PM
RX_Speed_7's Avatar
FB Forever!!!!!
thanks guys but the motor I was going after sold.... I'm going T2 now
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
The Shaolin
Sep 14, 2015 07:50 PM
