boost gauge question
Old Jan 31, 2010 | 05:02 PM
whitefcdrifter's Avatar
Boss
WA boost gauge question
ive had my boost gauge in my car for along time now but never wired up the light on it haha the wires are there and the light works, but i dont know what to wire it into haha, some one helps me so it turn on and off with my lights =)
thanks Eric
Old Jan 31, 2010 | 07:48 PM
Upgrayedd's Avatar
Double Dose
You need to tap into your harness in the steering column to the accessory wire for your headlights that only has power when the lights are on. You'll need a wire tester to find which wires have currents, unless you can get your hands on a wiring diagram, which I'm sure you could find in the FSM or 2nd Gen Tech section...
PS I miss you, Eric
Old Feb 1, 2010 | 12:54 PM
potassemon's Avatar
I know it's a lot of wire to install, but I just wired mine to the light in the ashtay thing. then zip tied all the wires up under the dash. I used that because I knew that it would be on wih the headlights on, and it would adjust with the dimming potentiometer
Old Feb 2, 2010 | 08:42 PM
Boss
you sir are pure og genius haha, good thing i got a **** ton of extra wire laying around
Old Feb 3, 2010 | 04:48 PM
jkstill's Avatar
Searching for 10th's
The light for the cigarette lighter also works.
It is right next to the steering column on the FD so is quite convenient, not sure about FB or FC.
Snoopy FD
Dec 8, 2015 01:45 PM
TerryD
Aug 23, 2015 07:40 AM
