T4 35r project results and 3 rotor tuning video
Old Jan 24, 2010 | 03:24 PM
G's 3rd Gen's Avatar
I finally got the car tuned last night. Ended up w/ 360 @ 13 lbs. and 420 @ 17lbs. The fuel pump wasnt holding pressure all the way on the high boost setting so I am going to get the rx7.com pump to compensate. This was done for pump gas (93) Afr's 10.8 on low boost and 11.2 @ high until the pump fell off a bit. Car feels good. Gaby Skern tuned in Orlando. My buddy got his 3-rotor t88 car done and made around 600 @ 15 and 831 @24 on c16. Here's the video of the race gas pull. http://www.youtube.com/watch?v=b7ozT2pcLMw Thank you to all and especially Goodfella(rich) for all your help! G
Old Jan 24, 2010 | 04:56 PM
Zero R's Avatar
Just in time to die
Congrats on the numbers, I'm sure it's a fun car.
~S~
Old Jan 24, 2010 | 05:45 PM
~S~
Appreciate it. Amazingly smooth strong powerband. Anyone thinking of ditching they're hi psi twins for a good responsive yet strong top -end this turbo set-up is for you. Again A-spec delivers .
Old Jan 24, 2010 | 05:59 PM
dregg100's Avatar
so you finally got the single in there!! i have an RP that id hook you up with if you want...
where's the vid of ur car!
Old Jan 26, 2010 | 02:03 PM
Ha! Wasnt too worried of getting video of my pulls. Thought the 3-rotor would stir some wows though. G
Old Jan 26, 2010 | 04:23 PM
ScorpionT's Avatar
Very nice!
Old Jan 30, 2010 | 10:58 AM
Scrub, Jhnrx7 and myself are down in Daytona visiting Garrett for the 24 hour Rolex race. I just got a ride in the car and it's just what I expected. Spools fast, pulls great to redline. That open WG definitely scared the **** out of pedestrians
Props to Garrett for undertaking this project by himself in his garage...... we race every year on the highways around DGRR, and I'm thinking this year I may have a problem
Old Jan 31, 2010 | 10:34 PM
datsun1200's Avatar
shut up you jack wagon
gaby skern that's what's up.......
Old Feb 1, 2010 | 06:05 PM
ErnieT's Avatar
Living life 9 seconds at a time
Sounds great, 600whp is at 15psi, then making 231whp additional on 6psi more is hard for me to believe. Not saying it wasn't done, but I'd be willing to bet more like 30psi.
Old Feb 1, 2010 | 07:06 PM
ChrisRX8PR's Avatar
I know you know your stuff Ernie so I am not trying to differ with you . However, I have seen crazy numbers on 20bs as in whp/psi.
My buddy from PR got between 715-735@14psi (cant remember exactly) with a GT55r (91mm) and hit 118Xwhp mark @ 25-26psi...that is a jump of about 400-450whp on just 11-12psi or about 37-40whp per psi. Assuming this car gets like 25whp per psi that would be 225-270whp more with that 9psi jump from 15 to 24psi... so 825-870...
Oh, and the reason I assumed less whp per psi for this as opposed to my friends is because my friend has semi-peripheral ported housings operating with valves and a stepper motor so his psi = alot of air, that and the turbo he is using is considerably larger and more efficient at moving lots of air.
I'm just saying it could be possible.
Chris
p.s. BTW, I just noticed you wrote down 6psi, maybe you thought that was the jump in pressure, it was actually a jump of 9psi
Old Feb 1, 2010 | 07:15 PM
ErnieT's Avatar
Your friend was also using a GT55R which is twice the size of this turbo. Like I said Im not saying it wasn't done, but 6 psi more and 231whp is a bit much. Actually I just noticed the video says its 27psi which is a bit more realistic.
Old Feb 1, 2010 | 07:41 PM
ChrisRX8PR's Avatar
Ahhh, you're right, the video does say 27psi...so from 15 to 27 that's 12...more realistic...
I see what you mean with the larger turbo...didn't know this was that small compared. This is a PT-88 so technically its like a GT4718R internally but the housings are smaller, hmmmm.
Do you mind if I ask what turbo you have in your 13b? Nice numbers.
Chris
Old Feb 1, 2010 | 07:47 PM
ErnieT's Avatar
Which time, lol...Tomorrow I will the my new Garrett GTX billett GT4202 71.9mm. I look foward to seeing this car at DGRR!
Old Feb 1, 2010 | 07:58 PM
ChrisRX8PR's Avatar
Oh really, hmm...so a GT4202r is what it takes....nice!
Chris
Old Feb 3, 2010 | 02:13 PM
yes it was 27psi. sorry for the wrong info. G
Old Feb 3, 2010 | 02:36 PM
ScorpionT's Avatar
Ernie, who is machining the compressor?
Old Feb 3, 2010 | 03:05 PM
ChrisRX8PR's Avatar
Its a new version of turbos that Garrett just released. They come with Billet Compressors. Search for Garrett GTX.
Chris
Old Feb 3, 2010 | 04:33 PM
ErnieT's Avatar
What he said
Old Feb 3, 2010 | 07:28 PM
ScorpionT's Avatar
Chris
Ive actually had a few of them in my hands already.
What he said
The GTX4202R is 75.8mm, and the GTX4294R is 70.3mm. Did I miss something?
Old Feb 3, 2010 | 07:51 PM
ErnieT's Avatar
GT-42X 71T
http://www.forcedinductions.com/productsgarrett.htm
I don't wanna take over this guys thread. I'll post pic's and all the info as soon as i get it.
Old Feb 3, 2010 | 08:01 PM
ScorpionT's Avatar
GT-42X 71T
Ok, now I see. Thats actually different from a true GTX, but I know what compressor is used in it.
Im done thread-jacking!
Old Feb 6, 2010 | 06:22 PM
No worries on the thread jack. working on my new fuel pump w/ 10 gauge wire plumbed through the lid w/ grommets and sealant. Hopefully it fixes the pressure @ high rpm. G
MoTeC
Sep 10, 2015 07:58 PM
82streetracer
Aug 23, 2015 09:28 AM
Clacor
Aug 14, 2015 09:17 AM
