Wanted:pics off extra fuel injector setups
Old Jan 23, 2010 | 01:08 PM
Speedworks's Avatar
I'm looking for some pictures off extra fuel injector setups. Preferably setups with injectors on the UIM or LIM.
If possible with some info on where you got the parts, what to look out fo (angle in the intake path), pointers too look out for
thanks a lot
Old Jan 30, 2010 | 09:10 AM
Speedworks's Avatar
up... nobody??
Old Jan 30, 2010 | 09:20 AM
PvillKnight7's Avatar
Additional injectors are not used exclusively on RX-7 engines. Try searching the world wide web.
Old Jan 30, 2010 | 10:23 AM
Syritis's Avatar
notice the two injectors on the greddy compression tube. a simple 5/16 rubber hose and hose clamps will hold stock pressure but i wouldn't trust it at higher boost levels.
these should be plumbed in with a Y fitting after the fuel filter and should have a pulsation dampener then Y'd again to each injector. this is why is not really practical for our cars when it much easier to increase the size of the injectors in the stock locations.
Old Feb 2, 2010 | 03:39 PM
NewbernD's Avatar
Tequila? ..it's like beer
aux injectors
Here's a pic of a spacer that went between your UIM and LIM and provided for additional injectors. I have seen a similar unit show upon eBay that provided for 8 injectors..
and another pic of injectors in the elbow..
Old Feb 2, 2010 | 07:34 PM
elwood's Avatar
Check the Single Turbo forum.
Old Feb 2, 2010 | 07:48 PM
elwood's Avatar
Oops -- thought I was on a different forum.
Have you searched for Ground Zero? I think they used to make a LIM with extra injector bosses.
82streetracer
Aug 23, 2015 09:28 AM
