Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek S4 NA RTEK 2.0 - Var Res Analog input stopped working??
Old Jan 22, 2010 | 11:57 PM
LargeOrangeFont's Avatar
Fistful of steel
I have an RTEK 2.0 for my S4 NA. I reset the palm and ECU as part of some other trouble shooting, and now the VAR RES Analog input is not working. It just sticks at a number. I had this configured for my wideband before and it worked great until recently.
While datalogging, if I click on the VAR RES parameter it says my ECU is not in analog mode. VAR RES Analog does not move.
I am running logger version 2.0.1 build 4. Is there a newer logger version that can fix this?
In the thread below it sounds like there is a newer version.
https://www.rx7club.com/showthread.p...ht=analog+mode
Should I just upgrade to the newest version of the logger?
Old Jan 23, 2010 | 12:50 AM
turbo2ltr's Avatar
yes you should update.
Old Jan 23, 2010 | 12:54 AM
Fistful of steel
Will do. Anything special I need to do or just uninstall and reinstall the software on the palm and plug it into the car?
Old Jan 23, 2010 | 10:42 AM
turbo2ltr's Avatar
delete the program off the palm, hotsync, then install the latest version and hotsync again. Note, unless you save them manually by making a copy out of the backup directory on your PC, you will lose your saved maps and logs. If you want to save them, hotsync first before deleting the program. Then copy the files out of the backup directory before doing the after-delete hotsync.
Old Jan 24, 2010 | 03:01 PM
Fistful of steel
UPDATE: I installed the new version of the PocketLogger on my Palm, and my problem has been solved. Var Res Analog input is working normally now.
smikels
Rtek Forum
May 12, 2016 12:34 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
andyvideopro
Aug 20, 2015 10:55 AM
smikels
Aug 18, 2015 01:26 PM
baconflavored
SE RX-7 Forum
Aug 12, 2015 12:07 AM
