Canadian Forum Canadian users, post event and club info here.
Stat gear berings
Old Jan 20, 2010 | 12:12 AM
10aeRX7's Avatar
Canadian Boost
Stat gear berings
looking at the parts micro fiche, there is 2 options for the bearing o.s (over sized) and standard. i have a s5 t2 motor which of the two should i be getting.
Old Jan 20, 2010 | 06:33 AM
Buggy's Avatar
I've Been Wankeled!
The difference will be the inner diameter of the bearing itself. To know what you need you have to measure the main journals on your eshaft and then find out what dimensions those bearings are. I know on a piston engine you want about 0.0005" to 0.0025" oil clearance between the bearing and the shaft for proper lubrication. Not sure about the rotaries but I can't imagine them being much different. So basically pick the bearing to match your shaft so you get good oil clearance.
Old Jan 20, 2010 | 03:00 PM
10aeRX7's Avatar
Canadian Boost
ok perfect thx
Old Jan 20, 2010 | 05:56 PM
misterstyx69's Avatar
Retired Moderator, RIP
..just wondering..Do you need a set of Needle bearings (Torrington) Bruno??..I got some new ones,in box,somewhere.
Old Jan 21, 2010 | 03:06 PM
10aeRX7's Avatar
Canadian Boost
the will come with the kit im orderings. thx
Old Jan 21, 2010 | 03:44 PM
Buggy's Avatar
I've Been Wankeled!
Hang on to those torrington bearings Dave. You never know when your engine will decide to eat one like mine did. Ended up as tiny shards of metal in the oil pan.
Old Jan 21, 2010 | 06:14 PM
Thanks for the Vote of Confidence!.Bump for Bruno.
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
