02 sensor
Old Jan 9, 2010 | 06:50 PM
MyLastEcstasy's Avatar
02 sensor
Why does 2nd rx-7 only have 1 wire for their 02 sensor?
Other Cars I look at have like 4,
so does that mean the one wire carries current?
Old Jan 10, 2010 | 10:08 AM
Aaron Cake's Avatar
Engine, Not Motor
The RX-7 uses a very simple EFI system. The single wire sensor generates it's own voltage using a zirconium based element. Heat for the element is supplied by the exhaust stream itself.
Later on, manufacturers went to heated O2 sensors which have their own little heater. Two wires are generally the heater, then two wires lead to the element (instead of grounding it through the body).
Old Jan 10, 2010 | 03:48 PM
also another dumb question, how bad the o2 sensor affect the idle?
Old Jan 10, 2010 | 08:49 PM
funkjaw's Avatar
It won't.
Old Jan 11, 2010 | 03:52 PM
Aaron Cake's Avatar
Engine, Not Motor
Correct, it won't at all. The FC EFI system only pays attention to the O2 sensor at light load cruising.
Old Jan 11, 2010 | 06:11 PM
ooooooooo thanks a lot guys
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
