Sequential and none sequential on a FD....
Old Dec 29, 2009 | 03:32 PM
RX_Alex's Avatar
Well the other day i talked to this guy that had a 93 rx7 and i asked him if it was a twin or single; and said its still a twin turbo but its not a sequential setup so i was wondering whats the difference from being a sequential setup and one that is not sequential but is stil twin?
Old Dec 30, 2009 | 02:43 PM
gracer7-rx7's Avatar
needs more track time
An answer to your question can be found in the very first thread stickied in this forum
https://www.rx7club.com/new-member-rx-7-technical-256/frequently-asked-questions-3rd-generation-rx-7-1992-2002-faq-fd-782404/
Scroll down to the N section.
Old Dec 31, 2009 | 01:15 PM
RX_Alex's Avatar
thanks i read but was stil wondering since its NS, does that mean the boost pattern stays in the same number of boost unlike the Sequential where it does the 10 8 10 pattern?
Old Dec 31, 2009 | 03:38 PM
Nope. NS means that both turbos are working together. Therefore no 8PSI transition between the first turbo running 10 PSI and the second turbo running 10 PSI. Both turbos run together, similar to a single turbo, so boost comes in around 4000 RPM at 10 PSI, or whatever it is set to, with very little boost below that.
Clear?
ls1swap
Jun 3, 2024 03:25 PM
Snook
Feb 27, 2021 02:54 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Snook
Oct 4, 2015 08:47 PM
