Speedo cable dangling! do I need a new one?
Old Dec 26, 2009 | 05:46 PM
masa_3100's Avatar
Rotary Fan in Training
Unhappy Speedo cable dangling! do I need a new one?
Ok after much research on the forums and some quick unscrewing i found that my speedometer doesn't work because the cable isn't plugged into the tranny! But definitely plugged into the cluster. I have no idea if i should just plug it back in or if I should go get a new one. so I took two pictures for you guys to help me out. The previous owner seemed to have undone it or broken it and left it tucked into the frame underneath! I think I need a new one but not sure so if anyone has one to spare or could point me in the right direction that would be great!
Attached Thumbnails Speedo cable dangling! do I need a new one?-p_00094.jpg   Speedo cable dangling! do I need a new one?-p_00095.jpg
Old Dec 27, 2009 | 01:05 AM
masa_3100's Avatar
Unhappy
I just noticed, if this was supposed to be plugged into the tranny does that mean my tranny has no fluid in it? And if so I should fill it up right away correct?.
Old Dec 27, 2009 | 08:19 AM
rxtasy3's Avatar
it's missing the actual cable that goes inside that casing. that end screws onto the side of the tranny. no it didn't loose any oil.
Old Dec 27, 2009 | 12:43 PM
masa_3100's Avatar
I guess that means im just gonna have to go get a new one.
Thanks for the help!
TeamRuffRacing
Sep 30, 2015 08:13 PM
Casual_John
Canadian Forum
Sep 26, 2015 01:47 PM
