1984 GSL-SE 13B will not start
Old Dec 24, 2009 | 04:42 PM
james78733's Avatar
ok i drove the car 30 miles 2 days ago then later on that day i went to start it and it cranked an cranked an killed the starter. so the next day the 23rd i replaced the starter and cranked it an it will turn over an not fire. I pulled the plugs cleaned them up an tested them for spark an they all sparked. while i had the plugs pulled i pulled the engine fuse an cranked over to clear then engine i could hear the compression come out the spark plug ports so i reinstalled the plugs then sprayed 1/2 bottle of sea foam in the throat of the therottle body an cranked it over to get the seafoam in the engine then let it sit all night. so today I reinstalled the engine fuse an cranked it over it let out some pops and smoke and damn near started an then just cranked. so i put more sea foam in the intake an circilated it in the engine and have it sitting again while i charge the battery. i also smell gas in the intake so i know it is getting fuel as well. IS it just severely flooded? what else can i do?? please help. thank you for your time an input. - Jerry
Old Dec 28, 2009 | 12:31 PM
diabolical1's Avatar
the simple answer is yes. it's probably just flooded and the plugs are fouled. i would do the de-flood procedure again and start with new plugs.
Old Dec 28, 2009 | 01:27 PM
Ms. DIY's Avatar
Ready or not...
You say you moved... Have you made an appreciable change in altitude? Perhaps opening the air intake for carb?
Old Dec 28, 2009 | 01:33 PM
Ms. DIY's Avatar
Ready or not...
Joke's on me. The notation Moved: seems to refer to someone moving your post? Not your declaration of a relocation. It's still good to consider your air.
Old Jan 2, 2010 | 11:54 AM
carnut1420's Avatar
dupon registry
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
Inspector71
Aug 26, 2015 12:06 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
