clutch adjustment
Old Dec 23, 2009 | 03:51 AM
TroyNic's Avatar
Troy
clutch adjustment
i have a 1984 sle se new master and slave, question about free play..is it really a tenth of an inch..i can barely feel it..please advise
Old Dec 23, 2009 | 10:50 AM
RotaryRocket88's Avatar
Top Down, Boost Up
Well, only you can measure it. Freeplay is just that little bit of movement before the clutch starts to engage the piston on the master cylinder. You should only really adjust the clutch travel if it's releasing on the floor or something similar.
Old Dec 23, 2009 | 11:08 AM
RTRx7's Avatar
Rammer Jammer
You really shouldn't be able to feel it. Less is better.
Old Dec 23, 2009 | 01:02 PM
Kentetsu's Avatar
However, a lack of free play could mean that the clutch is not fully releasing, which could lead to premature wear.
You can adjust the free play. Crawl up under the dash, and look at the push rod that comes off the pedal. That is where the adjustment is made.
Good luck.
Old Dec 23, 2009 | 01:09 PM
TroyNic's Avatar
Troy
Thank you I followed the service manual directions and less was better !
Old Dec 26, 2009 | 10:45 PM
Kentetsu's Avatar
Glad to hear it worked out for you. Now start racing it!
The1Sun
Sep 15, 2015 04:45 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
REX7&Z32TT
Sep 9, 2015 05:16 AM
Enzo1944
Sep 6, 2015 08:57 AM
