Air Pump Bypass?
Old Dec 11, 2009 | 10:10 AM
dffrx7's Avatar
Air Pump Bypass?
The air pump (smog pump) on my 94 twin turbo froze up & because of the way the belts are routed, I can't drive the car till I get a replacement (belt also drives water pump & I think also the alternator).
Is there any way to temporarily route a belt in a way that drives the water pump, etc, but bypasses air pump?
Old Dec 11, 2009 | 11:01 AM
gracer7-rx7's Avatar
needs more track time
Did you read the Private Message I sent you?
Yes there is a way to do that. You need to correct size belt. Run a string through the belt path to measure length and go to the parts store and get a belt of a similar size. W/o the airpump, the belt may slip and not provide sufficient tension to properly spin the water pump under hard acceleration.
Old Dec 11, 2009 | 01:43 PM
dffrx7's Avatar
Gracer...thanks!
Yes, I got the message & will post something on the classified thread when my post count gets high enough..
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Frisky Arab
Sep 4, 2015 06:17 PM
rotor_veux
Sep 3, 2015 07:10 PM
