Why is my boost dropping?
Old Jun 12, 2002 | 04:45 PM
RXTASY1's Avatar
-My Crappy Turbo? It's some type of hybrid with a bigger compressor on it.
-My wastegate spring? Maybe too weak to hold boost?
-My AVCR?
Would NOS remedy this problem?
Old Jun 14, 2002 | 03:48 AM
Dragon's Avatar
20B N/A Wide Body FC3S
Are you running a cheap blow off? It may be venting boost...
Old Jun 17, 2002 | 05:36 PM
Marcel Burkett's Avatar
Maybe , in fact most likely that new compressor isnt properly matched to your engine and isnt sypplying enough air to maintain the required pressure ratio at higher RPM.
Old Jun 19, 2002 | 02:02 AM
Ryde _Or_Die's Avatar
Are you losing boost as in every day you can't get quite as much or as you drive it doesn't hold boost well?
Old Jun 19, 2002 | 02:08 AM
machinehead's Avatar
kortez
How about backpressure?
vmerino
Sep 5, 2015 11:26 AM
AXA
Sep 5, 2015 10:06 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
gabescanlon
Sep 5, 2015 12:09 AM
