Sponsored by: CARiD
gauge does not read RPMs
Old Nov 28, 2009 | 08:14 AM
Snackman508's Avatar
my gauge does not read RPMs in my FD. The needle just bounces around, some times it works for 2 or so min after start up but then stops working. Im trying to figure out if its a bad gauge or sensor. So my question is where is the rpm sensor and how can i test it?
Old Nov 29, 2009 | 12:02 PM
middleman496's Avatar
i have the same problem bro.. my friend told me that his cluster broke twice now he's on his third one. but yea i'd like to know how to diagnose this problem because my speedometer doesn't work either.
Old Nov 30, 2009 | 04:30 AM
SanityAssassin's Avatar
Well, if FDs are anything like FCs the RPMs are actually read from the trailing coil pack. Probably not grounded properly, mine was loose and as soon as I tightened it up it worked like a charm!
However the speedometer for you middle man I'm assuming is still cable driven on FDs so that's not related.
Old Dec 1, 2009 | 09:19 PM
where can the trailing coil pack be found still new to the rotary.
Old Dec 3, 2009 | 08:42 PM
The way you can look at it is the leading and the trailing coilpacks are where their located on the car. The one in front of the drivers side shock tower is the leading, the one behind (the one your looking for) is behind the drivers side shock tower. Check to see if it's bolted down properly, so right by the brake booster and brake fluid reservoir, can't miss it. =p
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
Thor 18
Interior / Exterior / Audio
Sep 13, 2015 08:39 PM
TerryD
Aug 23, 2015 07:40 AM
