Inake thermo sensor Help!!!!
Old Jun 11, 2002 | 10:31 PM
Enthu's Avatar
Still has an RX7.
Exclamation Inake thermo sensor Help!!!!
My CEL had been coming on recently , and then shutting off. alot like what happened when I was naive and told I needed to replace the EGR valve since that's where the malfunction was. wish I had been on the forum this much back then.. So I did the Diagnosis shorting trick, and got code 11 "Intake Air Thermosensor
open or short circuit".
I have an Apexi Power intake installed on my car currently, and downpipe. Stock ECU. I'm guessing a short maybe since check engine light the light comes on occassionally and then shuts off. where is the sensor and what can I do to solve this?
thanks for the help guys
Old Jun 11, 2002 | 11:02 PM
Wargasm's Avatar
Weird Cat Man
The air intake temp sensor is located on the _underside_ of the intake manifold. See the big arches/ridges that send air down into the engine when you open the hood? It's on the bottom side of that thing. To get at it you need to take the upper intake manifold/throttle body off.
Brian
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
R|©haźd
Sep 24, 2015 11:39 AM
