choppy
Old Nov 19, 2009 | 04:01 PM
evilpb11's Avatar
choppy
Maybe its just how an rx7 sounds...I have a 1990 rx7 gxl..
heres the problem. everytime i start the car it will jump up to 3000rpm untill i give it a little gas. then it will be at about 2000rpm...you cana also here it has a pretty choppy sound to it...i know i live on a marine corps base but everytime i look up there not helos..i thought it might be the spark plugs. i took them out and they were disgusting. i bought new ngk spark plugs and put them in. the car started right up and went right to 3000rpm wich i thought would happen anyway. i hit the gas pedal and the rpm went back down to about 2000...i was pretty happy because i didnt hear the choppy sound anymore..i let it run a little bit longer and then it was happening again...? can anyone gimme a clue on what it is and what to do...i would appreciate it a lot....thank you
Old Nov 19, 2009 | 09:10 PM
w.sen's Avatar
In a Bucket
Accell warm up system its normal. I think if u start it in gear it goes up to 1500rpms.
Old Nov 19, 2009 | 11:35 PM
funkjaw's Avatar
On cold start it will normally jump to 3k, if you kick the gas it will go down to about 2k until it warms up. It does it to get the pre cats hot for emissions.
Describe the choppy sound in more detail... or better yet take a video of it and post it.
gracer7-rx7's Avatar
needs more track time
Yep that is normal. All RX7s do that. Most non-RX7s do that also. Maybe not as high as 3000 RPM but other cars do it as well.
Definitely post a vid if possible to show us what you mean by choppy.
Old Nov 20, 2009 | 11:35 AM
evilpb11's Avatar
it sounds like a back fire...but rapidly...just not as loud..or as if an engine was to missfire..and just kept doing it....i will deff try to get a vid up asap....
Old Nov 20, 2009 | 01:39 PM
evilpb11's Avatar
ok well..im not going to be able to put up a video right now. im taking off the radiator. whatever jerk owend this before me put an after market radiator on with a fan that was even connected right on...he also decided to leave the stock radiator on to. the aftermarket radiator was smokin after a couple revs or a 5 minute drive...also the low coolant sensor kept going off so im trying to get down to the point of that to....i would appreciate any advice on that to...i have a lot of work to do before i turbo this thing lol...
Old Nov 20, 2009 | 02:12 PM
funkjaw's Avatar
Wait what? He put an aftermarket radiator on and also kept the stock one on?
Old Nov 20, 2009 | 02:39 PM
evilpb11's Avatar
lol yea...i dont know why he did that but its off now..so now im figuring out what up with the aftermarket one..im not sure why it was smoking...trying to pinpoint it...
Copeland
14
Sep 23, 2015 12:59 PM
R7rexy
19
Sep 2, 2015 10:24 AM
fc3schick87
Feb 28, 2009 09:48 AM
KillaKitiie
11
Apr 23, 2006 10:13 PM
r71
Jun 2, 2003 12:49 AM
