trouble starting my 90 gxl :(
Old Nov 17, 2009 | 10:09 PM
yerRx7's Avatar
Rotary's "R" Us
MN trouble starting my 90 gxl :(
i bought this 90 gxl with a blown motor in it. i swapped out the motor and dropped in another S5 n/a motor from a 91 automatic FC. the flywheel and new clutch has been swapped over to this motor. last time i compression tested the motor before i took it out, the front was around 91-94 and the rear was around 95-99. after everything was put back together,(i used brand new mazda gaskets for the lower and upper intake manifolds) double and triple checked all the hoeses, all the wires are hooked up. when it comes to starting it, it will only crank but will not turn over. the motor cranks with compression still. i notice the BAC valve wasn't clicking so i replaced it with another one and it finally clicks. im going to assume that the motor is flooded really bad since i've done the unflooding trick mulitple times.
anyone have any suggestions?
Old Nov 17, 2009 | 10:11 PM
yerRx7's Avatar
Rotary's "R" Us
oh yeah and the car is completly stock.
Old Nov 18, 2009 | 10:36 PM
yerRx7's Avatar
Rotary's "R" Us
ok i just pulled my spark plugs out today to find out that there's no fuel being fed. all i see is oil on the plugs. what can cause fuel to not feed at all?
Old Nov 18, 2009 | 10:50 PM
rotorhead_izzy's Avatar
Stewiefied Racing CEO
is the fuel pump coming on?
Old Nov 19, 2009 | 02:19 AM
kustomizingkid's Avatar
Did you reverse the fuel lines when you installed them... did that once... got no fuel... lol...
Old Nov 19, 2009 | 01:54 PM
yerRx7's Avatar
Rotary's "R" Us
^^ and right you are. i reversed my fuel lines. got her running now.
now i have a new problem. she idles rough. lol
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
