Water temp reading 106+ wtf?
Old Nov 17, 2009 | 07:06 PM
hurleysurf24's Avatar
wtf rotary wtf
Isn't it suppose to be sitting at around 80ish?
Its hitting this with me only driving her about 1/2 mile, not ragging on it. WTF?
Old Nov 17, 2009 | 07:42 PM
jdmsuper7's Avatar
Looks ahead!
Your thermostat is stuck or you have a serious air bubble.
Old Nov 17, 2009 | 07:47 PM
wtf rotary wtf
yea i thought thermostat too. oh wells, off to the mazda dealer.
just didnt know if there was some crazy shennanigans being had inside the engine.
Old Nov 17, 2009 | 07:48 PM
wtf rotary wtf
oh and the temp gauge did some bouncing before it finally went in the H,
Old Nov 17, 2009 | 11:40 PM
bob13bt's Avatar
Fixed the wheelhop
Wow thats 222 F!!
How high can water temps get until housings warp?
How long were you driving at this temp?
Old Nov 17, 2009 | 11:43 PM
wtf rotary wtf
wasnt driving .. this was in my driveway. I shut it off once I saw it crank that high.
I think once you hit 110 = fuxor.
Old Nov 17, 2009 | 11:46 PM
*TOUCH*'s Avatar
Project P --- Pedospeed
i think the motor will take up to nearly 240F coolant temps, although you dont really wanna see anything over like 215F
Old Nov 17, 2009 | 11:50 PM
arghx's Avatar
rotorhead
108C (about 230) is the temperature at which the cooling fans on the FD and the Rx-8 go to full speed. Get above that for sustained driving and you should start worrying.
Old Nov 18, 2009 | 09:56 PM
ericgrau's Avatar
Clean.
Originally Posted by bob13bt
Wow thats 222 F!!
It's metal. A few hundred degrees at least. i.e., after the coolant boils and there's nothing touching the housing except steam and 4000 F combustion gases. Though I think the Racing Beat site talks about excessive apex seal wear too much above 200 degrees. Probably thermal expansion or something.
106C / 223 F is exactly the temperature of boiling 50% antifreeze at 0 psi. I'd replace your thermostat and check/replace your pressure cap just in case. Boiling = trouble.
Old Nov 18, 2009 | 11:18 PM
arghx's Avatar
rotorhead
well if the cooling system is working right, it will be running at 13psi
Old Nov 19, 2009 | 06:16 AM
*TOUCH*'s Avatar
^+1. thats the function of the radiator cap. it keeps the cooling sytem under pressure, greatly increasing boiling point
Old Nov 19, 2009 | 02:01 PM
wtf rotary wtf
im going to replace the cap as well then.
Old Nov 19, 2009 | 06:51 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
I had my cosmo to 253*F once when the fan shrowd exploaded and fucked up my fan
I kept it running for about 15min hovering around that temp and got it to a house with a hose and just missted the radiator till i got it down to 180.
Did an oil change that night and the oil came out like water. Drove on that motor another year before tearing it down, never had an issue
troym55
23
May 25, 2016 12:42 PM
sherff
Sep 12, 2015 12:22 PM
