fuel system for 400hp?
Old Nov 16, 2009 | 06:15 PM
523884FD3S's Avatar
AB fuel system for 400hp?
im the process of going single turbo and my goal is to make 400rwhp. i have a fresh rebuilt engine with 3mm apex seals, and a basic street port on the exhaust, no porting on intake. i have a greddy t78,fmic, and power fc. i am wondering what fuel system modifactions are needed to make this power? im thinking new rails, 850cc primaries and 1200cc secondaries (going on what others have done) and an upgraded pump? is this enough? to much? or is 400rwhp unrealistic without further porting?
Old Nov 16, 2009 | 10:59 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
550 primary's 1600 secondary's Upgraded single intake fuel pump, upgraded FPR
On a single turbo you should be able to get 400 easy on pump and even safer on alcohol injection.
I am running 850 Pri and 1600 Sec, Twin intake pumps, this @ 83% DC makes close to 600.
Old Nov 17, 2009 | 12:03 AM
523884FD3S's Avatar
AB
thanks that helps
Old Nov 17, 2009 | 02:04 AM
BuujinBejiita's Avatar
1986 Rx-7
If I may ask a question, I am doing a full build up on my FC and I got a wally 255, 720cc primaries an 1600cc secondaries, do I needed a bigger fpr? Thanks
Old Nov 20, 2009 | 03:13 PM
vipcivic's Avatar
bigger fuel pump, secondary injectors at least 1600cc, primary could stay 555cc,ecu of course
Snook
21
Sep 1, 2015 06:32 PM
82streetracer
Aug 23, 2015 09:28 AM
