quick miata swap question
Old Nov 16, 2009 | 03:28 PM
smwebb's Avatar
wondering if a first gen 7 sub frame would fit a first gen miata or if you need to modify a 2nd gen to fit. have a turbo II in my 85 already thinking of going miata instead. searched but couldn't find specifics... thx
Old Nov 16, 2009 | 07:25 PM
NCross's Avatar
I have a rotary addiction
I'd say modification is inevitable. All 3 chasis are different widths and have different engine mounting positions. Only thing you can do is build a custom motor and transmission mount.
Old Nov 18, 2009 | 02:17 PM
smwebb's Avatar
i was planning on cutting the subframe from my 85 se and then modding that since i already have the mounts set up for the turbo II. it seems to me this would be easier than starting from scratch? i'm not sure
Old Nov 18, 2009 | 04:59 PM
NCross's Avatar
So your mounting the front cover motor mounts on it? just find a good way to weld or bolt the frame to the Miata chasis and go for it. Only thing is you will need to cut your tranny tunnel out to clearance the 12a tranny since it mounts higher.
bb6guy
Oct 1, 2018 08:07 AM
astrum
24
Nov 15, 2017 08:44 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
