rx8 people are dumb please help me!!!
Old Nov 10, 2009 | 02:19 AM
outinnowhere3193's Avatar
Hello everyone lol so I know your work is with the rx7 and I'm on the 7 site. It just seems people don't know what they are doing with the 8's. My first engine went after 40k with about 5k of boost at 10psi. The second motor which is covered only made it like 3k and I had it built and tuned at pettit racing. I climb into boost at like 13's and by 5psi I drop down between 10.9 and 11.1 afr. I thought it was my timing that's why I had them tune it. Now I'm lost so I'm going to people who have experience...people who are putting out real power on a 13b. Just wondering if you could tell me what my split should look like and where my timing should be from idle up. Last I was wondering are you running the ALS seals...is that what you recommend.
My rx8 rotors are machined to hold the rx7 seal
I do premix
drive it easy till warmed up
and it's never seen the track since the turbo
Microtech ECU
oh and since tuning is so important...is there a way to wire the knock sensor the the microtech so you could see what it's reading..or is there a way... Does the knock sensor just send a ground single like a temp sensor?
Old Nov 10, 2009 | 08:58 AM
Zero R's Avatar
Just in time to die
I PM'd you for your thread in the single turbo section.
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
antman0408
Oct 5, 2015 04:33 PM
Captain Hook
13
Oct 4, 2015 06:35 PM
