Making a manifold
Old Nov 5, 2009 | 08:04 AM
creature546's Avatar
Making a manifold
What kinda pipe should i use, also schedual 10 or 40? thanks
Seth
Old Nov 5, 2009 | 09:48 PM
killahrx7's Avatar
dyno queen potentials
i use 40
Old Nov 7, 2009 | 04:36 PM
FrogedFab's Avatar
Using schedule 40 is safe because it has less chance of cracking. It also depends on what size tubing you're gonna run also because that changes how much heat the manifold will produce.
Old Nov 7, 2009 | 05:45 PM
SENZA PARI's Avatar
The wall thickness has nothing to do with the ability to withstand cracking. If you can't weld, nothing will hold up. If you're handy with the torch, sch10 is more than enough. Cheaper, lighter... Sch40 will retain heat slightly better, so it depends on what you're after.
2" sch10 pipe would be fairly ideal as the OD is 2.162", giving you the slight anti reversion lip that you'd want. Full penetration welds. Perfect...
Old Nov 7, 2009 | 06:05 PM
2" sch10 is exactly what i was thinking......
type i am think 304...that sound good?
Seth
Old Nov 7, 2009 | 11:22 PM
FrogedFab's Avatar
Actually wall thickness has alot to do with the ability to crack. Thicker wall= less heat. Less heat and a thicker weld will definitely mean less chance of cracking. You're best bet is to make sure you penetrate fully and back purge your tubing to add extra strength on the backside of your weld.
Old Nov 19, 2009 | 01:54 PM
skir2222's Avatar
I win
What kind of welder you using to make the manifold?
Old Nov 19, 2009 | 02:17 PM
FCNAred's Avatar
a giant synchrowave from 19-dickety-2
Old Nov 19, 2009 | 04:37 PM
mono4lamar's Avatar
In the burnout box...
Syncrowaves are EXCELLENT welders...
Old Nov 19, 2009 | 06:04 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Im using sched 40 304ss from mcmaster carr
Im also going to say that syncowave's are awesome welders. I have a Syncrowave 250 i bought for a song and a dance. Welds great from 1/8 steel butt welded to the 2" solid round to the 3" od 2"id 6061 tube ive had to push it too
Old Nov 21, 2009 | 07:01 PM
skir2222's Avatar
I win
synchrowave better be a damn nice welder being priced at 5000$
Old Nov 21, 2009 | 07:32 PM
craigslist! i got mine for $1200 (or 1500? i forget) with a rollaway and a pile of consumables
Old Nov 21, 2009 | 09:36 PM
silverfdturbo6port's Avatar
500+hp club
talk to A-SPEC thats where i am getting my stainless schedule 10. they use that tubing in all their manifolds and they are only like 1 7/8 dia.
Old Nov 21, 2009 | 10:16 PM
firstgensteve's Avatar
doce_A
"it runs off tears of small children" lmao...thats comedy.. my manifold was home grown, used racing beat's piping...it already cracked once. anyone know a good source of material?
Microtech
30
Apr 23, 2016 06:37 PM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
Engine stand ready
Aug 14, 2015 10:26 PM
