speed alert buzzer
Old Oct 22, 2009 | 03:36 AM
nicksta84's Avatar
Thumbs up speed alert buzzer
hello i have a 1987 rx7 series 4 turbo import and there is a a speed alert buzzer that sounds when above 107kmh and would like to remove it because the speed limit here in west aus is 110kmh
does anyone know the exact location of this buzzer and or what it looks like i have pulled part of the dash out to get a better look but to no avail .... please help
thanks
Old Oct 22, 2009 | 01:16 PM
JDMinard's Avatar
On a rx7, i dont know what it looks like, but on my 89 tt supra it was some sort of litle gray/silver box/fuse behind the cluster. Maybe if you throw us a pic or two it would be helpful to point it out
Old Oct 22, 2009 | 02:58 PM
funkjaw's Avatar
Speed alert buzzer? I didn't even know FCs had those. 107 kph is like 67 mph... that makes absolutely no sense for it to have a speed buzzer or governor at such a low speed. Then again I am in the states so it may be different for our FCs. Make sure it isn't your coolant or oil buzzer lol.
Old Oct 22, 2009 | 05:58 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Jspec cars have a speed limiter. It can be disabled by removing a screw on the instrument cluster circuit board. There's apparently the number '180' printed on the board next to it.
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/j-spec-speed-limiter-217977/
Old Oct 22, 2009 | 11:09 PM
JDMinard's Avatar
This is no limiter, but a speed alarm.
Jspec have this feature, if you run over ~105km/h... It goes ding ding and faster you go, more it "ding"
Old Oct 24, 2009 | 04:04 PM
akbubba47's Avatar
that sucks! good luck finding it
Old Oct 24, 2009 | 06:42 PM
black_7's Avatar
I can ask my boss lol, it was in my canadian FC
Old Oct 24, 2009 | 09:42 PM
nicksta84's Avatar
thanks
thanks guys hope it works am waiting on motor to be rebuilt cant wait to be back on the road again cheers
Old Jul 21, 2011 | 12:24 AM
nicksta84's Avatar
upon removing the screw beside the 1080 on the back of the cluster nothing has happened still beeps
Old Apr 5, 2019 | 06:40 AM
GypsidangerFC's Avatar
I am still looking for the solution to this problem as well it drives me bonkers!
Old Apr 5, 2019 | 07:47 AM
I found a post on an Australian forum that says to remove a screw marked "100k 120k", instead of the 180 listed above.
Old Apr 5, 2019 | 10:15 AM
Maxwedge's Avatar
Slowly getting there...
Tenured Member: 5 Years
The OP (back in 2009) was in Canada. You guys have this buzzer problem here in the States? My goodness, the speed limit on the PA Turnpike is 70 and you can pass a State Trooper doing 79 without him noticing. A buzzer on from 67mph and up would be unbearable.
Old Apr 5, 2019 | 11:27 AM
They are jdm imported cars.
Old Apr 6, 2019 | 03:41 AM
my 86 fc is from japan that's why I have this problem
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
WyomingTII
Sep 28, 2015 10:32 AM
