s5 na wont idle, engine light flashes
Old Oct 21, 2009 | 03:56 PM
gxl87turbo's Avatar
screw u guys im goin home
From: Findlay, Ohio for now. Thinking about moving in with your mom.
OH s5 na wont idle, engine light flashes
Hey guys I searched the forum and could not find a topic on this. I have a s5 na fresh rebuild thanks to ziig. Car starts but will die if you dont keep the revs up. When you let go of the gas pedal the check engine light flashes, then when you press it goes away. Car acts like the tps is bad. Any help with be appreciated. Thanks
Old Oct 21, 2009 | 04:03 PM
BOOSTD 7's Avatar
Persona non grata
Sounds like a big vacuum leak ...
Old Oct 21, 2009 | 04:06 PM
gxl87turbo's Avatar
No its not a vacuum leak, that wouldnt explain why the check engine light flashes when you let on/off the gas pedal.
Old Oct 21, 2009 | 04:51 PM
walken's Avatar
Registered Loser
pull the codes
Old Oct 21, 2009 | 06:20 PM
gxl87turbo's Avatar
How do I pull the codes?
Old Oct 21, 2009 | 06:54 PM
BOOSTD 7's Avatar
Persona non grata
That's poor logic for ruling out a vacuum leak. On a newly installed rebuild you could have numerous problems, they could be related or not.
Old Oct 21, 2009 | 08:22 PM
VividMP5's Avatar
Here ya go....http://www.rx7city.com/ecucodes.htm
Old Oct 23, 2009 | 05:14 PM
gxl87turbo's Avatar
its a bad tps
Kyo
Apr 13, 2019 09:24 AM
ncds_fc
Aug 15, 2015 10:06 AM
